• Just another scan here... left since last time: 3819 R and new appeared (both reported already on LyngSat): :69:
    4069 R 3800 1/2 DVB-S2 QPSK - more than 11dB over LM on 4.9m...
    Fortunately, FEC 1/2 enables me to lock this mux/service.
    I didn't escape to the locked Eye Radio on 4195 H, 400, 3/4. :3:
  • 3964 R 27500 3/4 DVB-S
    3964 R 27500 3/4 DVB-S is back on with Arabsat package.... about 10.0dB over LM on 4.9m
  • 3964 R 27500 3/4 DVB-S is back on with Arabsat package....
    ...and left again... :175:
  • qwer seems that 4193L Vision4 also had left?
    Oops... can´t catch them all in one BS...
    Vision 4 is still active...
  • Probably new here...
    3769 L 27500 3/4 DVB-S, SNRT Arabsat package in clear (12.7dB over link margin on 4.9m)
  • It is difficult to catch with 1.25 m.
    5.1 dB are not anough for a picture, although the programs were scanned in without names.
  • The signal is now a little stronger. Strong enough for reception with dropouts.
  • Kaonsat LNB tests with a 1.50m antenna.
    To get the correct polarity Left/Right, the plate has to be placed to the side of the probes. The plate manufacturer has only one channel between the two probes. I had to measure which is exactly half where to place the plate outside the probes, where there is no channel for it.
    Are you guys working with this LNB? If so, did you place the plate between the probes or outside them?
  • I visited 20.0E yesterday with a 1.50m antenna and Mediastar 5G LNB.
    Good signal for this radio mux (4195 L) with a low symbol rate (400).
  • Just my unchanged scan in year 2025... :72:
  • 4184 L, 10542,5/6,16APSK-new, (or new symbol rate)
  • Just my end of november scan - nothing new appeared...
