11498 V 950 ACM, looks GS, no lock only around 1db .
60.0°E Intelsat 33e
11498 V-no lock,just 2.8dB ,
Instead found:11090 V,900,1/4,S2,ACM-new GS
My Scan on 180CM
Most of them are in GSE, except 10982 Vertical 11116 Horizontal 11129 Horizontal 11146 Horizontal. There are a lot of frequencies. I can't screen shot them all. But if someone requested a specified frequency, I will screen shot.
Some changes for the list - probably from different beams:
11464 V 22912
11568 H 23325
11627 H 20656
11648 H 1000
11661 H 1000
10981 V,16270,1/4-has left,
10997 H,31426,3/4-has left,
11034 H,5066,5/6-has left,
11043 V,24475,3/4-has left,
11099 V,10480,2/3-has left,
11103 H,24474-has left,
11122 V,22570-has left,
11136 H,36855-has left,
11155 V,13730,8/9-has left,
11176 V,9998,1/2-has left,
11190 H,15000,1/3-has left,
11464 H,26665,1/3-has left,
11497 H,14929,3/4-has left,
11582 V,1000,3/4-has left,
1,1583 H,1000,1/4-has left,
11629 V,26950,5/6-has left
Almost all the muxes above have left the satellite or no longer appear on the spectrum, and some have a new symbol rate.
10967 V,8150,1/3,S2-GS,new symbol rate,
10986 V,23722,1/4,S2,Multi 1->250-GS,new symbol rate,
11047 V,15936,3/4,32APSK-GS,new symbol rate,
11151 V,22500,8/9,16APSK-GS,(Bryce on FS),
11498 H,25414,3/4,32APSK-GS,new,
11679 V,18326,3/4,16APSK-GS,new symbol rate.
11627 H 20656
11627 H still lockable here... this one looks like Spot beam -not specially for my region- ...
/edit: ... more for the list...
11004 H 4166
11074 V 2191
11084 H 24500
11158 H 13173
11567 H 25420
11655 V 26952
12084 V 14918
Probably new here:
11046 V 20328 - very low signal from my place
11088 H 33333
11145 V 32075
11583 V 1000 - not new, already listed here by KooLy - low signal here
11667 H 1485
11675 V 21000
10727 H,4000, 8/9, 16APSK- GS,new,
11042 V,26824.8/9,16aOSK- GS, new,
11060 V,1000,1/4,S2-GS, new,( N_Stanislav on his spectrum, above),
11106 V,9521,1/2, S2, Multi 1-254)- GS, new,
11167 H,1000,1/4,32APSK- GS. new( N_Stanislav on his spectrum, above),
11167 H,1000,1/4, 32APSK- GS, ( N_Stanislav on his spectrum,above),
11523 H,25297, 1/4, S2- GS,new,
11675 V, 21000,1/4, S2- GS, new,
11262 V, 64000, 1/3- needs to be (re)checked by other users.
satesco i wonder that you can't lock any channels from Russia beam.
Let's not forget that this Intelsat has cells/spots directed on several zones, some on small areas, which makes their reception impossible.
The two Russian programs, Telekanal 78 and Nika TV, are in northeastern Europe. Even if the signal is not favorable for me, I happen to catch them, especially in the cold season (see previous posts at 60.0E).
I still managed to get the two Al Ghad radio programs on 11491 H, so that's something, too.
I didn't understand why you didn't scan at 11200-11400 HV. I would have wanted you to check 11262 V, 64000,1/3. Although I locked at a weak signal, I'm not sure if it is also active, or if the two polarities overlap because they are not perfectly delineated.
I would like to know your signal on the sub-band transponders,10700-10950 HV.
Since 59.7°E Ovzon-3 is co-located with 60.0°E Intelsat 33e, probably Ovzon-3 has frequency ranges that IS-33e does not have.
These are 10700...10950 and 11200...11450 MHz. I found 3 strong data transponders there, and a few weak unlockable ones.
10852 V 40000 ACM/VCM 8PSK 8/9
11262 H 64000 ACM/VCM QPSK 1/3
11387 H 64000 ACM/VCM QPSK 1/3
The 0.3° difference is enough to distinguish between the two, I'm pretty sure these 3 come from Ovzon-3.
(I posted this earlier today at satellites.co.uk) -
