New frequency 11511 V 4150 5/6 8PSK
No chance here.
No chance here.
No chance here.
New Frequency 11508 V 2024
I have to wait until the snow is out of the antenna.
Those not locked frequencies(mine and Dreamsat´s) were probably feeds .
Now there is another TP-11493 V 13330 3/4 8PSK,ca 5db.
I found this TP at 60E, not sure if it is 33e or...
12564 V 7400 3/4 8PSK
No peak visible here. It can be IS-33e indeed, or maybe nearby KazSat-3 ?
Whatever it is, very exotic!
Not there atm. SR looks like feed.
On again, I hope dreamsat is somewhere near.
Edit: 18:45 off , as I said it has to be a feed...
Indeed,11493 V is there but with very weak signal in my area,but I'm not sure that is feed for has mode 32apsk! If someone could get it lock
Regards
Here is a new topic for the IS-33e Ku feeds, messages were split off from the Ku DX topic. Hope I found them all!
Thanks@hvdh.
I hope we will see locked feed from this position one day...
Still very weak and bad mode +FEC for us
no chance here
Nothing also from here .......
Next one for "no lock" collection...
It is a feed.
Cactus @satclubpl
New Transponder
11517 V 3750 8/9
no Lock and 10,1 dB
ZitatOriginal von dreamsat
New Transponder
11517 V 3750 8/9
no Lock and 10,1 dB
it is a feed again,
http://www.satclub.pl/60-0e-in…904-t229-135.html#p252031
But you are close to lock, you can wait and try later.Here only 8db.
(hvdh: Moved to Feeds topic)
New 12074 V 4149 5/6 "TVC HD"
danke, keine Chance hier mit 180; da sind wir zu weit westlich und die Modulation (8PSK 5/6) ist eh nicht freundlich.
