60.0°E Intelsat 33e
  • New frequency 11511 V 4150 5/6 8PSK
    No chance here.
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Original von marval450
    No chance here.
    :83:
  • Those not locked frequencies(mine and Dreamsat´s) were probably feeds .
    Now there is another TP-11493 V 13330 3/4 8PSK,ca 5db.
    TBS 6983
  • Zitat
    I found this TP at 60E, not sure if it is 33e or...
    12564 V 7400 3/4 8PSK
    Not there atm. SR looks like feed.
    TBS 6983
  • Zitat
    On again, I hope dreamsat is somewhere near.
    Edit: 18:45 off :88: , as I said it has to be a feed...
    TBS 6983
    2 Mal editiert, zuletzt von marval450 ()
  • Zitat
    Indeed,11493 V is there but with very weak signal in my area,but I'm not sure that is feed for has mode 32apsk! If someone could get it lock :126:
    Regards :125:
  • Thanks@hvdh.
    I hope we will see locked feed from this position one day... :91:
    Still very weak and bad mode +FEC for us
  • Nothing also from here ....... :91:
    Owner of Cy Satellite Center
  • Zitat
    Original von dreamsat
    New Transponder
    11517 V 3750 8/9
    no Lock and 10,1 dB :37:
    it is a feed again,
    http://www.satclub.pl/60-0e-in…904-t229-135.html#p252031
    But you are close to lock, you can wait and try later.Here only 8db.
    (hvdh: Moved to Feeds topic)
    TBS 6983
  • danke, keine Chance hier mit 180; da sind wir zu weit westlich und die Modulation (8PSK 5/6) ist eh nicht freundlich.
    1 Gib. 150
    1 T90
    1 Gib. 125
