Happy, to share my receptions, for yours. Yes, I agre that you, moved my post, sorry for posting in the wrong place.
28.2°E Astra 2F <UK beam>
28.2E U.K. beams 0-24 hour DX receptions in Hungary II.
Hi, all!
I presenting to you, my second testing result, and receptions measurements report, now to the 11306 V frequencies. (The testing date: 2021.12.11)
2. Testing results, details
The firstly, and the nowing testing process difference, that i applicated the minimal changing the anything system devices, and i finished also few correction settings:
- the changing, that i applicated: used me, the new, designed by me, second version scalar feedhorn
- Modified to the LNB skew,
- Rim behind the scalar ring, down to the zero points,
- Dish elevation setting up to, cca. + 1 degrees
The early testing showed, that the 11306 frequency H, and V polarity, not 90 degrees int the received. Therefore, this 11306 V polarisation, new LNB skewing needed ago, this cca. -1 degrees moving, to accessing to the best signal. (That realized true? Don’t know securely, but this is my experience.)
2. Measurement report
The second frequency testing, difficult reception task.
28.2E 2F UK beam 11306 V https://www.lyngsat.com/muxes/Astra-2F_UK_11306-V.html
The SNR, in the 11306 V polarity cases to 7,3 dB maximum (Picture, 11306V SNR Max.jpg). If you remember my first study, or measurements report, this 11306 H in the case of polarity power maximum to 5,6 dB ago.
The upper and lower wave, or valley-period strong fluctuation of the signal level, observed in now. (Picture, 11306V SNR Min.jpg)
(I think maybe the scalar ring phase interference and/or quenching causes.)
Picture 11306V End.jpg shows the closing time of the entire reception interval with 6.8 dB SNR values. Uptime: 24:03 HH:MM, BER:4,7E-3
Conclusion of the second measuring:
The testing also now was successful, this is the receptions also are available daily 0 to 24 hours, its my QTH . (Great! Action, Movies, and GB News HD, etc.)
Thank you for your attention, I welcome all corrections, recommendations, comments, clarifications and additions, and I am also available for further questions.
Thank, you this reading also my second report.
Best, regards
SaTom
Hi, Pipino!
Thank you!
My QTH location:
SatQTHmap – Google My MapsKöszönet minden műholdvadásznak, akik megosztják a vételi lehetőségeiket a közösséggel. Feliratkozás: satqthmap@gmail.comwww.google.comThis maps showinng, many more Hungarian DX-r friends also, select and klicking the actual nicknames. The page autozooms in the concrete areas and showing the QTH palce, plus more leftt side, list more DX receptions, and pictures.
Yes, i now using the Invacom QTF-031. This LNB, very good working the cross polarity isolations, this is function very important int the DX, and my LNB testing also showing, that this is LNB the biggest sensitive converter.
I few (one or two) years maked one LNB test, is Invacom, Inverto, MTI, and more with products. If would like, i' am happy to share it , this report/post.
Best, regards
SaTom
The list says that there are channels, but unfortunately, after searching for this transponder, nothing scans anything, but the signal beam shows as much as 11db.
Skandynavia (near Malmó) 180cm antenna
channels went from that frequency. I think it was a test !!
They are testing 11306 H 27500 again
Stable reception Antenna 180cm Skandynavia (near Malmó)
11306 H 27500 5/6 (copy of 10964 H 22000 5/6)
Alles was vom UK-Beam hier ankommt wird doch immer gern genommen
Ähnlich, aber eine Spur noch weniger wie im Beitrag #11 von Stephan94 kommt im nördlichen Niederösterreich an.
Hätte eigentlich schlechteres erwartet.
dF signal loop must be more, then +/-dF signal search
Today tests with the Channel Master 180cm antenna
Sweden (near Malmó)
He is receiving beautifully today tr.11426 V 29500 8/9
Obecnie bardzo dobre warunki odbioru wiązki UK.
Viaplay Xtra 10dB
Antena 180 Scandinavia (niedaleko Malmó)
28.2E U.K. beams 0-24 hour DX receptions in Hungary III.
Hi, all!
Few day early ago, i maked the new reception measuring, int the 28E UK beam, 12128 V polarisation. This reception, difficulty in my QTH, because DVB-S2 8PSK 2/3 parameter, and my location Hungary, Pest county.
That was my goal, that receptions C/N Lock status up to 24 hour, int the all time Locked.
Sorry, i dont speak good in the English, therefore the totally reception report, please read it by the google translater.
Bests, regard
SaTom
Congratulations on your success on 28.2E, the UK spot.
You could have posted your article on this forum even if translated with... Google. More important are the illustrations to your text, especially since most of us here use the same DVB applications.
Regards
28.2E U.K. beams 0-24 hour DX receptions in Hungary IV.
Hi, all DX-r!
After previous ( RE: 28.2°E Astra 2F <UK beam> ) and the special reception report, my next new report. (Making date, 2023-Sept-08)
This report contain, maybe one easier reception frequency with UK beam out in Hungary.
28E 2F UK beam 12129 V
DVB-S SR-FEC: 27500-5/6 C/N lock: 6.5 dB
The aim of the study series, the 24 hours C/N Locked reception status, int the all measurnig time.
Reception report:
This picture showing the starting time. SNR 7 dB, maybe not highest, but Locked, and have 0,5 dB LM margin. The 5/6 FEC dont help to the reception, in spite stabilty good. Pictire, and sound processing, without in the freeze, and error free.
This the minimum SNR value 6 dB, but even now active Locked in the C/N status. Quality 60%, Level 30% is lower with early ago.
Higest SNR in the testing time 8,1 dB. This the idealy dish settings, and satellite position state, in the time window. (The principled maximum DX velaue, in the moment time)
What this the suddenly Quality level drop? The highest and lower SNR value not relateing the events. The sudenly decrassed, and suddenly normalized process what can cause?
This pictures showing reception report closing, the ending time. SNR 6,7 dB, Quality 33%, Level 60%, BER 5,1.E3, and the finish, the Uptime: 2433 :-)
Conclusion, the testing the was successful, the receptions are available daily 0 to 24 hours, its my QTH.
Have nice day!
Best regards
SaTom
(Sorry, i don't perfectly my English. Google translator was help partly for the translation of my report.)
Dear, satesco, Feci01, Andreasgrdx, and dear all!
Thank you reactions!
This UK beam receptions in Hungary, very difficulty. I working hard the receptions night, and day. I maked many reception test, device test, and device planning maked, and the project is not over. : -)
Waiting for me, the IBU modification to flange, and the Andrew feedhorn replika test. (Thank for production to zoro67!) I think this two modification may cause further surprise in the UK beam receptions for me.
If I endig the 28E UK beams, next studys priorites 26e Badr satelites. :-)
Best regards
SaTom
