Many thanks to cjcr for the new version which is now freeware.
Blog post - http://ebspro.net/blog/category/blog/
http://ebspro.net/download/
EbsPro v. 17.0.0.0 Beta available
http://ebspro.net/blog/ebspro-17-beta-has-been-released/
EBSpro ALPHA v18.0.0.0 (changelog) – Feb 25, 2022
Thanks @Christian
- Added experimental audio/video *player in Signal Analyzer (can be used from SidePanel and from TS Analyzer)
- Added internal PID filtering support (no need to unmark "No PID filtering" in streamreader.ini, now this work is done in ebspro's engine).
- Added link-margin support for SA, Main Window and Positioner (with red-bar autoadjust)
- Show input bitrate in SA. - Improved search field in the SidePanel Scanner (press ESC to clean a search).
- Detect no data input in TSA scanning for SidePanel (this bypass the TSA timeout that takes longer.)
- Added SNR-bar in status bar of main window (also, small redesign of status bar)
- Abort scanning if PAT table reach timeout (don't wait for other tables in this case). This make scan much faster for some transponders.
- SidePanelScanner now stops scanning process faster when is needed. - Improved TCP stream connection handling - Added support for PLS code in the SEARCH_RESULT structure (Up-to date StreamReader.dll needed -included-, old versions don't will work well).
- Detect FFTScan support in Device Info. - Improved support and handling of allsats.txt database.
- Improved handling of device info from streamreader.log and also add temperature reading if is supported by device.
- Fixed a bug that doesn't save/remember the last checked status of the scan ranges.
- Fixed a bug handling TSA Streaming that can make some timeouts scanning dvb tables.
- Fixed encoding mode when handling streamreader.ini file that causes streamreader.dll don't read settings well.
- Fixed MISSel crash and continuous calls to MIS selection function in DT-Mode that make stream unstable.
- Fixed potential crash using diseqc under some circumstances. - Small improvement in USALS calcs.
- Some small fixes here and there. - Update AllSats.txt database.
- StreamReader updated to version 1.2.4.124 (new cards supported: 6902SE, 6904SE, 5930, 6903X(v2), ...)
Alles anzeigen
Problem mit dem neuen Version von EBSPro
den wird von meinem Firewall ( avira) vollig abgelehnt
und in quarantaine sofort verschoben
Problem with the new version of EBSPro
which is completely rejected by my firewall ( avira)
and immediately moved to quarantaine
Mein Rechner mit Avira hat das Installationsprogramm gelöscht.
Avira Option für 10 min. aussetzen und von anderen Laufwerk installieren, danach wieder aktivieren.
Windows Defender ist problemlos.
My computer with Avira deleted the installer.
Suspend Avira Option for 10 minutes and install from another drive, then reactivate.
Windows Defender is fine.
mit Bitdefender problemlos
habe ich wie femi gemacht , jetzt geht ..... einigermassen
bei mir funktioniert aber diese neue Möglichkeit nicht.
internal player ist grau ?
Komischerweise VLC auch nicht
TSreader ist OK , auch light alloy und transedit gehen ??
Erst Transponder im Scan anklicken, das Signal Analyzer Fenster öffnet sich. Im TS Analyser entsprechendes Pid anklicken und im AV Player gibt es dann das Bild.
First click on the transponder in the scan, the Signal Analyzer window opens. Click on the corresponding pid in the TS analyzer and the image will appear in the AV player.
Ich glaube , ich habe verstanden .
VLC und ABC Content analyser sind bei mir für IQmonitor eingestellt
(udp://@127.0.0.1.2103 )
, so können beide Programm nicht mit EBS gut funktionieren
"Added experimental audio/video *player in Signal Analyzer (can be used from SidePanel and from TS Analyzer)"
"StreamReader updated to version 1.2.4.124 (new cards supported: 6902SE, 6904SE, 5930, 6903X(v2), ...)"
TBS 6902se card supports BLScan, not RFScan.
the HD channels not work... only sound and the screen is black
SD channels are working
Are there specific settings?
Well, I could confirm, tested on Astra ARD Transponders.
Maybe we need any filters, buttons I still not found
