03.9°W Amos-7 <Middle East>
Lockable today:
11035 H 6081 2/3 DVB-S2/8PSK.
New.
11047 H 5000 2/3DVB-S2/8PSK - Changing parameters
Lockable today:
New.
Okay, nothing for me here from this beam...
(only -2.3dB on 11047 H 5000 2/3 and no signal on 11035 H)
Excellent Feci01 for locking vertical polarity in your area
As is well known, sunny and cold weather is favorable for weak reception, like this Middle-East spot. As usual, 11061 H is the strongest and most stable throughout the day.
Please, the one with a larger antenna, check if there is still an active frequency with 500 symbol rates at 11043 H.
Thanks
Just my poor -most unlocked- results in horizontal spectrum from ME beam at this position. Big problems according nearby 5.0°W position and my setup and place.
11033 H 6083 2/3 DVB-S2 8PSK - nearly nothing
11040 H 500 (GS) - 3.6dB, lock
11047 H 5000 2/3 DVB-S2 8PSK - up to 1.4dB, unlocked
11062 H 4500 1/2 DVB-S - 0.8dB, lock (edit)
11541 H 3702 3/4 DVB-S - 3.9dB, unlocked ("smooth lock" in BS) (edit)
11035 V 6083 2/3 DVB-S2/8PSK.
...indeed, I can confirm what feci01 found out:
11034 V 6083 2/3 DVB-S2 8PSK - -1.5dB, unlocked
11541 H,3701,3/4-For the first time I locked
Locked on the limit today from my place.
11541 H 3702 now in central Poland
My signal
11541 H 3702 3/4 DVB/S
hello torrex12
your results are exceptional, for 1.80m
You always talk about scandinavia,
But at the beginning of your messages you showed a map of Poland
around Przasny, and on your screenshots everything is written in Polish.
I don't believe Poland is in Scandinavia.
Scandinavia is big; from the North Cape to southern Denmark.
If you could say a little more precisely where you are located
Thanks in advance
My signal
Laminas 2700
11542 H 3703 3/4 DVB/S
witaj torrex12
Twoje parametry są wyjątkowe, jak na 1,80 m²
Zawsze mówisz o Skandynawii,
Ale na początku swoich przesłań pokazałaś mapę Polski
okolice Przasnego, na Waszych ekranach wszystko jest napisane po polsku.
Nie wierzę, że Polska jest w Skandynawii.
Skandynawia jest duża; od Przylądka Północnego do południowej Danii.
Gdybyś móc zrobić, gdzie się znajdujesz?
Z góry dziękuję
You probably know me from the SatClub forum, but unfortunately you won't see me there anymore due to the change in the forum rules.
But that's not what I wanted to tell you about.
If you are asking for my location, I have two.
One is in Sweden, the other in Poland.
In Sweden, because I work here and I have two 180cm Channel Master antennas installed here.
If I'm on vacation or a little off from work, I'm here
a few weeks in Poland.
Until recently, in Poland, I was assembling and installing the Channel Master 240cm antenna. This is my new arrival :)
Now there will be signals from Sweden, from a location near Malmo.
I don't know if I can post my pictures of antennas here?
There are 3 antennas in the first photo, they are in Sweden
the second photo shows my new Channel Master 240cm antenna
