01.0°W Intelsat 10-02 <S1/3 Eu.>
  • Intelsat 10-02 -
    11471,896MHz - Vertical - SR: 13308,49 Ks - 3/4 - DVB-S2 QPSK2 Pilot : OFF
    Bitrate : 19,802 Mbit/s
    Service name: ROH
  • 11465 V,9748,3/4,Dvb-S2/8PSK,CCM-Dubarry Park Dirty
    11477 V,9748,3/4,Dvb-S2/8PSK,CCM-Dubarry Park Clean
    Edited once, last by satesco (February 13, 2015 at 10:16 PM).
  • Currently active feeds
    11462,V,4937,56,30,|10.9 dB TV Klan Biss
    11498,V,4610,34,150,|11.2 dB CNN
    12515,V,3330,56,22,|13 dB B311DGI-Sport_Digi Brasov
    12519,V,3681,56,132,|13.2 dB Digi Sport Oradea
    12523,V,3748,45,21,|14.2 dB B 186 DGI
    12529,V,4750,56,150,|11.9 dB B 101 DGI
    12535,V,4980,35,134,|14.4 dB DigiSport HD(HUN016) Biss
    Borovo Naselje Croatia
  • 11502 V,2220,3/4,Dvb-S2/8PSK,CCM,Single-TV Norway E/S
  • 11508,V,7498,34,21,|10.7 (6.67) dB; 12:10 12/1/2016
    Provider: "Links Broadcast""UKI 457 CREED"VIDEO 4: 2:0 1920x1080 -fps 9785kbps 16:9
  • 11526 V,7400,3/4,Dvb-S2/8PSK-News feed
  • 11487 V,3332,7/8-BUL 009
    11492 V,3332,7/8-BUL004 NOVATV
  • 11005V 9600 DVB-S2/8PSK 3/4
    from Norway
  • Some more atm.
    Two shown here:
    11472 V 14000 2/3 DVB-S2/HD 8PSK
    11499 V 13310 3/4 DVB-S2/HD QPSK
  • As I said previously,
    IS 905 will going inclined orbit, a part of contrbutions services will moved to 1°W IS 10-02
    :46:
    Today I had the oportunity to do a test with Intelsat (thanks holidays meetings ...)
    here is a test on TXP 310XL
    it was available only few seconds for fun, no video modulate.
    12511 V 3302 5/6
    :72:
  • 12652 H 14400
    Service Name: NOR 044 Encoder 1
    Provider Name: NEP Norway
    12551 V 3600
    Service Name: TV2 Norway Encoder 1 HD
    Provider Name: TV2 Norway
  • Danke VodzigorLans :76:
    Hier die Bilder für diese beide Transponder.
  • Thor 5-6 - Intelsat 10-02 .8W 3592 TBS 5990 DVBS/S2 Tuner A 12510 Vertical 2599,964 16APSK 4/5 DVB-S2 ON 0.35 Normal CCM 8,283 3,508 10,4 -54 MIS: 0, BER: 0,0000000, Time to lock: - ms 21.12.2018 18:47:12
  • We have separate toppics for this position, ME beam and Europe.
    This is ME so your posts will be moved to "Europe" :72:
    Kathrein 220cm , KU+C,
    Original von marval450
    THX ,now i see!
    /merged in this toppic by qwer.
  • 12507V2100 maybe was feed, 80Mbit Video,total 100Mbit
    Variables:
    Thor 5-6 - Intelsat 10-02 .8W 3592 DVBS/S2 Tuner A 12508 Vertical 2100,055 32APSK 4/5 DVB-S2 ON 0.35 Normal CCM 8,337 2,835 0,0 -56 MIS: 0, BER: 0,0000000, Time to lock: - ms 24.01.2019 17:08:18
    Video: MPEG4 Video (H264) 1920x1080 25fps [V: h264 high L4.0, yuv420p, 1920x1080]
    Audio: MPEG Audio 48000Hz stereo 128kbps [A: mp2, 48000 Hz, stereo, 128 kb/s]
    Allgemein
    Vollständiger Name : C:\!Records\.8W_12507,642_V_2100_(2019-01-24 17.12.19)_dump.ts
    Format : MPEG-TS
    Dateigröße : 5,29 MiB
    Dauer : 3 min 48s
    Modus der Gesamtbitrate : variabel
    Gesamte Bitrate : 194 kb/s
    Video
    Menü-ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Codec-ID : 27
    Dauer : 3 min 48s
    Audio
    Menü-ID : 1 (0x1)
    Format : MPEG Audio
    Format-Version : Version 1
    Format-Profil : Layer 2
    Codec-ID : 3
    Dauer : 3 min 48s
    Bitraten-Modus : variabel
    Kanäle : 2 Kanäle
    Samplingrate : 48,0 kHz
    Video Verzögerung : -222 ms
