Are this signals new for this position (11700 - 11950 V polarization), I think they are from 68.5E ? Signal is very low, 11850 V 30000 DVB-S2 is under 0dB. From what beam and satellite are this transponders ?
68.5°E Intelsat 36
Sure looks like Intelsat 36 Southern Africa beam.
Peaks are in the right place: 11728 - 11768 - 11808 - 11848 - 11888 - 11928.
These 36 MHz transponders exist in both H and V, and have C-band uplink (quite uncommon).Of course, nothing in my location, not even peaks.
I can confirm this signal on 11850 V 30000 DVB-S2 (-2.8dB on 2.2m) from my place.
Finally I can get 11850 V 30000 DVB-S2 8PSK shown in CrazyScan BS.
FEC 2/3 (probably not correct)?/edit:
11770 V 30000 DVB-S2 only with -10dB under "Hard-Lock".
Nothing else in spectrum from my place. -
Probably correct, Multichoice planned to use Intelsat 36 for expansion of DTH TV.
Much more is not available here
Finally I can get 11770 V 2/3 30000 DVB-S2 8PSK with CrazyScan BS, even when it´s shown as -10dB.
In the DStv forum (Multichoice South Africa), there is an up to date post listing the transponders used, including 11728 through 11888 V of Intelsat 36.
http://forum.dstv.com/showpost.php?p=190199 -
Above link to the old DStv forum became dead because the forum was entirely deleted, and replaced by another (ugly) one.
In the new forum, the same contributor "Optimist" posted a transponder list on 19 December 2018:
https://community.dstv.com/t5/…ngle-View-HD-5s/td-p/8752
Pasting the IS-36 transponders here, in case the forum gets deleted again:
11728 V.... HD 108, HD 120, HD 124, HD 170, HD 175, HD 187, HD 325....DVB-S2
11728 H....HD 135, HD 136, HD 171....
11768 V....(for MC's use only - ignore)....
11808 V.... HD 111, HD 116, HD 145, HD 163, HD 198, HD 240, HD 320....DVB-S2
11808 H....HD 210
11848 V....HD 138, HD 139, HD 140, HD 157, HD 191, HD 193, HD 195, HD 212....DVB-S2
11888 V....981From another post of 23 January 2019:
https://community.dstv.com/t5/…nsponders-added/td-p/9786
This morning the following was added to our MC system, on IS36;
11768 Horizontal
11928 Vertical - this one is the first purely Hi band transponder.
This is a technical expansion, it doesn't necessarily mean any new channels coming.To decode these channel numbers, see here for example:
https://www.tvchannellists.com/List_of_channels_on_DStvIt's quite remarkable that after several years, nobody in South Africa cares to update Lyngsat/Flysat on IS-36 activity!
Original von hvdh
Finally, an Anonymous contributor has informed Lyngsat.
https://www.lyngsat.com/Intelsat-36.html -
Forgot these ones here... todays dreamsat update on DXtv.
Just my -10dB on two TP possible (no fake) - can´t get parameter in BS at this time.
My scan.
Thanks for reply pawelwa!
I still wait to "see" this one in BS...
...only for stats... -3.0dB two days ago now.
Just another look on this satellit... still "-10dB" (no fake) at my place on these two TP: 11808 V 30000 and 11849 V 30000.
Tonight on SA beam;
11728 V 30000 (-10dB)
11808 V 30000 (-2.5dB) /edit: a short time later
11849 V 30000 (-2.7dB) /edit: a short time later
Tonight on SA beam;
11828 V 30000 (-10dB)
I will try tonight to lock these tps but i think it will be a little bit difficult .......
Signal increased... (sorry bad joke)
11728 V 30000 (-10dB) - no changes
11808 V 30000 (-2.1dB)
11849 V 30000 (-2.0dB)
