Hi,
I hope, I´m on the right position?
Probably new:
3723 R 1210 5/6 DVB-S2 8PSK
It looks like an Ethiopian Channel?
PS: Signal for 3723 R increases more to the west (0.3°) in comparison to the other frequencies from 51.5°E (attached scan).
Hi,
Probably new:
I guess 3715 R of 53.0°E pushes away 3723 R of 51.5°E a little.
While the higher 51.5°E frequencies are in the clear.
Thanks hvdh, I think you´re right!
I don't know the beam bt I have absolutely no sign of it from my QTH
PS: with nearly the same SNR values for other frequencies.
You´re right, Feedsat, 3723 R has left again. Probably a test or feed?
ok, finally 3723 R is active again
Thanks for checking again Feedsat.
It´s Walta Television from Ethiopia.
PS: Merged 3723 R reports to Feeds>C, I´m sure it´s a feed now.
On again, 3723 R.
On again with todays signal on 3723 R.
On again, 3723 R.
Are you really sure that is a feed ?
In my opinion it's a regular contribution, I have scanned this satellite dozen of time and it's always there, morning, afternoon, evening.
What is your point of view ?
When I posted this earlier (17.04.) I saw something like a "playback video" (sorry can´t explain in english). Also strange "onscreen display" was shown (attached pic, here: ????????)
But of course I´m not sure, probably it changed now to regular service.
OK, let's wait and see few weeks.
As you probably noticed, there is 5 hours in advance between our local hour and the on screen clock.
You might be right finally, this should be a feed
I hope I´m on the righjt position here. Don´t know what this is. According ID it looks like a feed.
No clear video...
3835 R 3000 3/4 DVB-S2/HD 8PSK
No clear video...
Still here today (probably a regular encrypted service? Let´s wait.)
3718 R 3254 3/4 New feed freq (frozen pic)
PS: EBC on 3727 R is off air
Not often Feeds here I think
3716 R 2284 5/6
Scan - probably some changes:
3641 R 1820 3/4 DVB-S2 8PSK, ID: SEE (probably only occasinal?)
3714 R 2608 3/4 DVB-S, ID: OBNM (OBN from Ethiopia, I think and probably only occasinal?)
/edit: I merged above reports in feeds section: 3641 R and 3714 R have left again.
Active again.
