06.0°E WGS-1 (relocated)
Thank you too, for finding the relocated WGS-1.
According visual observation, WGS-1 was relocated again, from 24.0°E to 6.0°E.
Relocated and then it confirm this thread, this is WGS-1
I just realized this satellite is also KA Band C equiped and few frequencies are active.
/edit by qwer: LINKs disappeared (01.08.2020).
2 active TP
20243 L 21300 2/3 (no lock from my QTH)
20787 L 21300 2/3IP over DVB
2 active TP20243 L 21300 2/3 (no lock from my WTH
My first experiences in band C on 1.2m dish, using a simple plastic plate.
Lockable here:
20787 L 21300 2/3
No sign of signal on 20243 L for me.
Okay, now I can see 20243 L 21300 2/3 as unlocked here too...
IP over DVB
Locked 20243 L 21300 2/3 DVB-S2 QPSK today.
One more, but weak signal, unlocked:
20610 L 21300 2/3 DVB-S2 QPSK
Tried under constellation monitoring today. Nothimg new lockable.
Also tried with IQmonitor, found (several times), but unlocked:
20865 L 2766
Just my current (here: linear) spectrum (20,5GHz-21,2GHz) with Inverto IDLK-SINL20-KAKU-OPP and modified CrazyScan Version 1.0.2.146.
Todays circular left scan.
PS: 21073 L 1972 (GS)
20243 L 21300 2/3 (no lock from my QTH)20243 L is possible from my place today.
Nothing else new.
/edit: linear scan.
Changing SR now:
20787 L 22035 3/4 DVB-S2 QPSK
Just another try with Inverto IDLK-SINL20-KAKU-OPP and CrazyScan Version 1.0.2.146 on 1,8m (Invacom feed), using plastic plate inside.
No thing in my Area here too
I constantly receiving this signal using Inverto Twin Ka Circular Dual polarity.
20502 L 22032.667 3/4 DVB-S2 QPSK
PS: Ignore CS polarization.
The only thing that irritates me a little is the "Inverto Twin Ka" LNB
I edited those 2 lines inside StreamReader.ini Some frequencies are working nice for me; up to 20642 MHz
IFStart=250
IFStop=2450
