    Original von dreamsat
    20158 L 45000 near 49,0° East ??
    Can it be Turksat 4B at 50.0°E?
    4B may have VSAT 19.7...20.2 GHz like Turksat 4A.
  • From my QTH, no signs of this signal
  • My circular spectrum.
    /edit: correct LOF now.
    Hi wellikan,
    only a bad circular spectrum from my place (position 50.0°E). :72:
    Circular left wide TP scan with Inverto Twin WHITE Ka Circular Dual Polarity LNB on OPPOSITE POLARITY!
  • ANew scan omicom.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
  • Cool and thank you feci01 - I think, they are GS (Continuous stream)? Please re-check them again... :71:
    I listed 19936 L and 20186 L with SR 19050 here, click!
  • Just my circular left spectrum... probably same signal on 20074 L (SR?) as wellikan in april ´20 scan (7.0dB on TBS 6903X - nothing with TBS 6903).
  • No change.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
  • Just a scan in upper band B circular left range (using band C LNB). No changes.
    Signal form that peak de-creases...
    Summer 2022 circular left spectrum - not totally sure about satellite/position...
