11090 H,10000,3/4,Dvb-S2/QPSK,ACM,Multi 21-Data
74.9°E ABS-2/2A
11086 H, off
...ZitatOriginal von satesco
11090 H,10000,3/4,Dvb-S2/QPSK,ACM,Multi 21-Data11085 H,21242,3/4,Dvb-S2/QPSK,ACM,Multi 21-Data(new symbol rate)
Active again.
12533 V 44950 4/5 DVB/S2 QPSK -
There is a very weak TP,
12277 V 2615 DVBS, found with IQ mon. , checked many times.
Original von marval450
There is a very weak TP,12277 V 2615 DVBS, found with IQ mon. , checked many times.
CS can detect it.
12277 V 2615 looks strong today,but no lock with anything.
F15 shows up to 5db,I tried X810, BS does not find it, manual scan shows some dbs, no quality.
Crazyscan can not find it, so it is probably not DVBS.
All posts about this TP can be moved to data section.
hvdh: done!
12398 H 60000 QPSK2, MIS ?
12398 H 60000 QPSK2, MIS ?Tried, but can´t lock it (yet?)...
New Data.
12332 V 20661 3/4 DVB-S2/32APSK.
12388 V 7141 4/5 DVB-S2/32APSK.
12395 V 7146 2/3 DVB-S2/16APSK.
12041 V 4166 3/4 DVB-S2/32APSK. -
New:
12334 H 5924 3/4 DVB/S2 QPSK -
Original von pawelwa
New:
12334 H 5924 3/4 DVB/S2 QPSKPlease check if it is the same symbol rate you found last time.I have another one.
12333 H,1481,3/4,CCM-Data,new symbol rate(?)
I can confirm.
NO LOCKED at my place. -
No signal at all of 12334 H from here. For sure is not Mena Beam
Thanks pawelwa and @Kypros for checking I'm sorry you didn't lock it.
But maybe you're both lucky to lock-12240 H,68500.I think you need at least 10dB for this transponder12240 H I locked it.(see on S2X generic stream)
Reception of 12241 H
I'm glad I'm not alone in receiving 12241 H.Because the signal is very strong in your area and with the big antenna you have,I'd ask you to try to lock 12320 V,which to me is 7.5 dB.Try manually to lock it with symbol rates over 65000 Ks.
I hope you make it.
I hope you make it.
Unfortunately i have not signal from 12320 Ver ......
