New:
3953 V 10000 1/2 DVB/S QPSK ?
93.5°E Gsat-17
Vertical !
Could this be the new Gsat-17, launched June 28? -
Scan of the day.
3993 V 10000 1/2 DVB/S QPSK
3953 V 10000 1/2 has left, -
Thank you pawelwa!
New topic, I am confident now this is not Insat-4B (12 * 36 MHz, 3700...4200 H only). As we know, Insat-3A that had Vertical C-band is already end-of-life.
I paste here from sac.gov.in website, because found only in Google cache:ZitatGSAT-17 satellite is planned as a replacement for communication services of INSAT-3A and INSAT-4B satellites.
It will provide continuity of Fixed Satellite Services (FSS) in Normal C, Upper Extended C bands.
It will also provide Mobile Satellite Services (MSS) in S-band and Data Relay and Search & Rescue services in UHF band.The satellite will have wide coverage including India, Middle East and South East Asia regions in Nor C-band,
Southern Part of Indian Peninsula and Antarctica in Lower Ext. C-band,
Indian Mainland, Andaman and Nicobar, Lakshadweep islands in Ext. C-band,
Indian and its surrounding regions in S-band,
and global coverage in UHF band.Equipment’s:
24 Normal C-band transponders,
02 Lower Extended C-band transponders
12 Upper Extended C-band transponders,
02 + 02 MSS (Forward & Return link) transponders
01 DRT and SAS&R transponder
Normal C-band will be 3700...4200 H/V
Lower Extended C-band probably 3600...3700 range (below that is WiMax hell)
Upper Extended C-band will be 4500...4800 H/V -
Scan of the day.
4041 V 10000 1/2 DVB/S
3993 V has left. -
4005 V 10000 1/2 DVB/S (Changing frequency)
3953 V 10000 1/2 DVB/S QPSK (Changing frequency)
3954 V 10000 3/4 DVB/S QPSK (Changing FEC)
3868 H 2500 1/2 DVB-S
Original von atef 0
3868 H 2500 1/2 DVB-SThis is 93.5° E GSat-17
/edit by qwer: Merged atef 0 report above in this toppic.
Original von pawelwa
Yes pawelwa this is true
After converting the dish in the direction of the satellite 93.5 ° E GSat-17
The signal increased significantly
But it works in the direction of the two satellites
There seems to be a mistake in turning the dish
Thank you anyway to correct
