Eutelsat 3A -
12707,579MHz - Vertical - SR: 2962,422 Ks - 3/4 - DVB-S2 8PSK Pilot : ON
Bitrate : 6,602 Mbit/s
WAAR TV SNG
Eutelsat 3A -
WAAR TV SNG
Eutelsat 3A -
11521,214MHz - Vertical - SR: 1499,682 Ks - 5/6 - DVB-S2 8PSK Pilot : OFF
Bitrate : 3,716 Mbit/s
Service 02
Eutelsat 3C - 3.1E
12678,937MHz - Vertical - SR: 9598,13 Ks - 3/4 - DVB-S2 8PSK Pilot : OFF -Coding Mode : CCM
Bitrate : 21,394 Mbit/s
D-115
feed in Deutsche Sprache
Italian Feeds are rarely FTA
probably a backup according to the SR
11013 H 4800 3/4 Moto race, start in the seconds
I have found a feed that i cannot lock but can stream... usually this happened to me only at 11W. I think this is s hardware problem...
Can anyone check it and post full and correct data.
3.1e 11196V3720 religion stuff
TBS blind scan do give me correct sr but modulation is always different...
Hi VodzigorLans,
it´s: 11197 V 3720 5/6 DVB-S2/HD 8PSK
ID: AL-KAFEEL (VPid 515, APids 4126, 4128)
Thank you for checking. It is good we have something lockable in 10950-11200V range here now.
11197,V,199,34,1,|-37 dBm, 20.4 dB; 19:49 9/10/2016
Very strange signal!The only thing you can lock in DVBDream-data
absolutely no sign of this signal from my QTH
11648 V 2219
10961 H 10000
10973 H 10000
on
New frequency
11111 H 4652 5/6 DVB-S2 Qpsk
QuoteOriginal von atef 0
New frequency11111 H 4652 5/6 DVB-S2 Qpsk
No, it is a feed, your own report on flysat...
Feed section
QuoteOriginal von marval450
Feed section
Yes, he seems to be confused
For not following up
Thank you for the alert
Shafik_ 01 :look like feed :93:
Eutelsat 3B 3.1E 11662 Horizontal 2099,828 8PSK 5/6 DVB-S2 OFF 0.25 Inverted CCM 5,199 2,623 13,4 -45
I don't know if this is a feed or not
Enosat put it feed in flysat last year !
Eutelsat 3B 3.1E 11693 Vertical 2999,745 8PSK 5/6 DVB-S2 OFF 0.35 Inverted CCM 7,440 4,048 13,3 -46
I would say this is now a full-time channel, Holy Imam TV HD, seems to be present every time I scan this position.
feed 12690 H 2000 mpeg4 religion feed in small space between data and Greece tp.
Fees active 11507 H 1800
about CIA and...
Eutelsat 3B - Rascom QAF 1R 3.1E 0031 TBS 5990 DVBS/S2 Tuner A 11612 Horizontal 2849,927 QPSK 3/4 DVB-S OFF 0.35 Normal CCM 3,940 3,846 7,0 -52 MIS: 0, BER: 28,9100000, Time to lock: - ms 21.12.2018 19
59
