New:
10956 H 1849 7/8 DVB/S
10953 H 2200 3/4 DVB/S - "NO LOCKED"
Not sure yet if feed or regular prog?
78.5°E Thaicom 8 <Steerable>
Original von pawelwa
New:
Not sure yet if feed or regular prog?Great pawelwa!
I can confirm these (as no locked > not correct FEC) from my place too.
Great catch pawelwa!
I got one !
:127:
Found a frequency plan for Thaicom 8, SE-Asia beam!
Uplink range is 13.75...14.0 GHz H/V.
Downlink ranges 10.95...11.2 GHz and 11.45...11.7 GHz, both H only.These are only 12 transponders, there must be 12 more for the other beams (S-Asia or steerable).
Now:
10961 H 1200 5/6 DVB/S2 8PSK is empy.
10956 H 1849 7/8 DVB/S - is off.Edit.
There is a channel. -
Now:
10961 H 1200 5/6 DVB/S2 8PSK - is empy.
10956 H 1849 7/8 DVB/S - is off,Thanks once again, pawelwa!
Got 10961 H as no locked in my area with 2.2m.
/edit: Up to 8.9dB
Merged todays reports into feed section.
10962 H 1200 5/6 DVB/S2 8PSK is on . No lock,only about 8db...
Original von marval450
10962 H 1200 5/6 DVB/S2 8PSK is on . No lock,only about 8db...Yes it was on a few minutes ago now, but signal was only max 6.0dB this time for me...
Very weak signal now from my place, changing SR:
10960 H 2800 5/6 DVB-S2 8PSK
Signal on my place
Morning check:
10960 H 1850 3/4 DVBS
Signal was much stronger few minutes ago , up to 7db, now only this:
Morning check:10960 H 1850 3/4 DVBS
On again now, 10960 H 1850 3/4 DVB-S, unlocked from my place (2.2m).
Two active feeds now, both unlocked from my place:
10959 H 1850 5/6 DVB-S2 8PSK
10961 H 1200 5/6 DVB-S2 QPSK
/edit:
10957 H 1850 5/6 DVB-S2 8PSK, unlocked
Stronger atm, still waiting for first lock from my place:
Now there is a weird situation.
Switched on two frequencies,
10969 H 1850 5/6 8PSK
10962 H 1850 5/6 DVBS
The second one I can lock, signal is from -10db to 11db .
Looks like those TPs are mixing or affecting.
Qwer , you have a chance.
E: typos...
Thanks marval450 - my first lock here:
Finally, congrats..
E : now 10954 H 2200 3/4 DVBS on.
10954 H 2200 3/4 DVBS weak for an analyze
10959 H 1850 3/4 DVBS - super strong
Today's scan.
Active four feeds.
10957 H 1850 5/6 DVB/S2 8PSK
10959 H 1850 7/8 DVB/S - LOCKED
10961 H 1200 5/6 DVB/S2 8PSKEdit:
10959 H 1850 7/8 DVB/S - is off.
10961 H 1200 5/6 DVB/S2 8PSK - is off. -
On again:
10959 H 1850 3/4 DVB/S
