I've got only this one for now
Only 1.42° above the horizon
New:
3954 V 8887 3/4 DVB/S
Edit.
3953 V 10000 3/4 DVB/S is off.
New I think:
4141 H 4250 3/4 DVB/S
RTA Kabul
DD SAHYADRI
4012 H 8600 Auto RVB-S
New:
3849 H 4250 3/4 DVB/S
Edit.
QuoteOriginal von rysiuhelix
DD SAHYADRI
FEC 3/4
New ?
3802 H 3800 3/4 DVB-S DD NATIONAL 3C
New:
4085 V 30000 5/6 DVB/S2 8PSK
Today strong signal
New TP.
3835 H 2900 3/4 DVB/S2 8PSK -Not sure yet if feed or regular prog
3831 H 3330 3/4 DVB/S -Changing SR
New.
3982 H 2900 3/4 DVB/S2 8PSK
4044 H 2900 3/4 DVB/S2 8PSK
3977 H 3330 3/4 DVB/S - Changing SR
4039 H 3330 3/4 DVB/S - Changing SR
3835 H 2900 3/4 DVB/S2 8PSK - Still active!
Receiving from 93.5E with Gibertini 150cm ... 0.6 ° above the horizon
[SATTYPE]
1=0935
2=Insat 3A-4B
[DVB]
0=21
1=3721,H,6249,34,1 ;-59 dBm, 6,5 dB
2=3735,H,4250,34,1 ;-50 dBm, 6,0 dB
3=3735,H,4250,34,1 ;-59 dBm, 5,0 dB
4=3830,H,3330,34,1 ;-58 dBm, 4,4 dB
5=3841,H,6249,34,1 ;-47 dBm, 4,9 dB
6=3869,H,2500,12,1 ;-47 dBm, 2,3 dB
7=3926,H,27498,34,1 ;-40 dBm, 8,9 dB
8=3952,H,6249,34,1 ;-41 dBm, 6,3 dB
9=3961,H,6249,34,1 ;-41 dBm, 5,2 dB
10=3961,H,6249,34,1 ;-49 dBm, 5,9 dB
11=3970,H,6249,34,1 ;-41 dBm, 3,1 dB
14=3977,H,3330,34,1 ;-41 dBm, 5,9 dB
15=3992,H,6250,34,1 ;-40 dBm, 5,6 dB
16=4001,H,6249,34,1 ;-40 dBm, 7,7 dB
17=4012,H,8600,34,1 ;-40 dBm, 5,4 dB
18=4032,H,6249,34,1 ;-41 dBm, 0,9 dB
19=4052,H,8599,34,1 ;-49 dBm, 0,9 dB
20=4061,H,4250,34,1 ;-40 dBm, 7,7 dB
21=4150,H,4000,34,1 ;-43 dBm, 6,1 dB
New TP.
4150 V 1660 5/6 DVB/S2 8PSK
QuoteOriginal von pawelwa
New TP.
TP is OFF
It was probably feeds?
TP is OFF
Active again.
4149 V 1660 5/6 DVB/S2 8PSK ACM/VCM
The signal in the C-band at 93.5 E is better than in the Ku-band in my area,for which it can be locked even with smaller antennas.I have to admit that most locked transponders are transmitted in qpsk,a favorable parameter for a weak signal.Those who can reach this position have big chances to catch this bird
Scan of the day.
New TP.
4177 H 1660 5/6 DVB/S2 8PSK ACM/VCM
New TP.
Today tr is OFF.
Active again.
4177 H 11664 5/6 DVB/S2 8PSK ACM/VCM - Changing SR.
