• Hello
    how can I insert Lav filters in the 4T2 player
    in setting I only slowid and elecard
    on my pc I installed the Lav that I use with smart dvb
    the 4T2 are not visible
    google translator sorry
    thank you
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • google translation
    show an image we'll get better.
    T2-MI multistream nice to see in SmartDVB,so you do not need it 4T2 analyzer.
    Borovo Naselje Croatia
  • ok I know that smart dvb stores T2mi
    but with smart dvb my cpu and 10% with filters Lav
    with 4T2 it is 39% with FFdshow filters
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • Für eine 32 bit Version muß auch LAV filter mit 32 Bit installiert werden. Vielleicht liegt es da dran ?
    Ku-Band: 2.20m Kathrein , Octagon PLL Lnb
    C-Band: 2.36m Hirschmann , Corotor , Zinnwell Lnb
    KA-Band: 1,80m Kathrein , EGIS, KA- und KU Band LNB IDLK-SINL20-KAKUO-OPP
    Tbs 6983, 5925, Openbox 810, Dream 7080 HD
  • my version 4T2 0.10.63
    /edit by qwer: Sorry , attached files have disappeared with changed forum software on 01.08.2020.
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • This is a 32 bit version.
    lav Filter 32bit: c: \ Program Files (x86)
    lav filter 64bit: c: \ programs
    you need lav filter 32bit
  • who please help me to run the 4T2 sw on my pc?
    It hasn't worked since I upgraded to win 10
    installed and removed several times replaced the stream reader, inserted the string 4T2=1 but it doesn't start
    either with crazy scan or with ebs pro
    also tried in RF bda but no boot
    with win 7 no problem
    thank you
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
    This is because Win 10 didn't re-register your program.
    In my IQmonitor program, the 4T2 program works without a registration key in demo mode.
    This is a legitimate mode of operation, but requires a TS.ts transport stream file.
    IQmonitor creates such a file when locking a signal, and then you can start the 4T2 analyzer
    :74:
  • Code
    I would like to know where to download the program
    direct link please
    and especially how to install it
    since i tried a few times in the past but i was not able to get it to work
    settings please
    thank you
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • Code
    sorry to have to say this despite all your GREAT
    I work but this program is too difficult for me
    If someone can give me a hand step by step to configure it
    thank you
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • Code
    I understand your effort to help me but the program is too difficult for me
    every time I start the sw the 6925 blocks me and I have to restart the pc
    if there was a video where you see the correct installation and then also correct settings I would be grateful
    I can't learn 170 settings for one program
    I am sorry
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • You can also use 4T2 as a stand-alone program and load the *.ts file from any other program.
    The system crashes are not due to the IQMonitor, nor to the TBS6925. That definitely other causes!
  • You have not set the correct path in the [Parser] section of your IQMonitor.ini file. (I have red marked in picture)
    For example:
    [PARSER]
    Java=C:/Program Files (x86)/Java/jre1.8.0_161/bin/javaw.exe
    TSRLite=C:/Program Files (x86)/Cool.stf/TSReaderLite/TSReaderLite.exe
    TSR=C:/Program Files (x86)/Cool.stf/TSReader/TSReader.exe
    VLC=C:/Program Files/VideoLAN/VLC/vlc.exe
    MPC-BE=C:/Program Files/MPC-BE x64/mpc-be64.exe
    4T2ContentAnalyser=C:/Program Files (x86)/ABC/4T2 Content Analyser/ABC4T2ContentAnalyser.exe
    4T2INI=C:/Users/your_user_name/AppData/Roaming/ABC/4T2 Content Analyser/ABC4T2ContentAnalyser.ini
    TrEdit=C:/Program Files (x86)/DVBViewer/TransEdit.exe
    Also in Subfolder "positions" from IQMonitor I'm missing the 0130.ini, maybe there are no ini-files (blue marked in picture)
    They are not necessary, but recommended
    satellites.ini.IQMonitor.zip
  • Code
    know how to do it
    it's easy for you but not so much for me
    some time ago I was successful then with the change of pc I lost everything
    help how to do it thanks
    Lodi sud
    laminas 180
    tbs 6983-6522-6903X
    rover tab 900 plus
    proform KTI h 180
  • Bearbeite im Verzeichnis (wo du den IQMonitor installiert hast) die IQMonitor.ini.
    Das geht auch mit Notepad (in Windows enthalten).
    Die Zusatz-Programme, die du verwenden möchtest müssen natürlich auch auf deinem PC installiert sein.
    Im [PARSER] Abschnitt müssen die Verzeichnisse angegeben sein, wo sich die Programme befinden, damit sie der IQMonitor verwenden kann.
    Nachdem alles richtig eingetragen ist, die QMonitor.ini speichern.
    Beim Start des IQMonitor sollte nichts grau hinterlegt sein.
    Edit the IQMonitor.ini in the directory (where you installed the IQMonitor).
    This can also be done with Notepad (included in Windows).
    The additional programs that you want to use must of course also be installed on your PC.
    In the [PARSER] section, the directories must be specified where the programs are located so that the IQMonitor can use them.
    After everything has been entered correctly, save the QMonitor.ini.
    When starting the IQMonitor, nothing should have a gray background.
  • Code
    despite your effort I don't understand how to do it
    in the picture are the things you wrote
    when I start the sw the writings are always grey,
    I always notice that in the forums they always write you have to do this or do that
    but how to do it sometimes you don't write
    I thank you for the time you dedicated
    Anthony
  • Folder TransEdit :
    Open Computer,open Windows (C:)
    Move folder Transedit in folder Windows (c:)
    Then do it with each folder, sort by (PARSER)
