Welkome toufiksmso ![]()
You are in Algeria just like flie?
Because the peaks 12540 H and 12660 H in your scans look quite strong.
I think they are a different beam, and more difficult to see in Europe than the peaks below 12.5 GHz.
thinks hvdh , Yes flie he is my friend
>Tests going on right now...
12540 H
12660 H
On again:
12280 H
Now/on again:
12320 V
QuoteOriginal von qwer
Now/on again:12320 V
12320 V it's a first! Now only 12400 V, 12440 V, 12480 V are missing below 12.5 GHz.
So you get equally strong carriers above 12.5 GHz. There goes my assumption of two beams! But if there is only one beam, why two Ku transmit dishes? Maybe the 2nd dish is for Ka then, some misinterpretation is easily made.
hello all
& thank you very much ![]()
Welcome my friend toufiksmso ![]()
like what you said ...there are new test today
12546H MAY BE 12550H NEW ONE
& 12664H or mAy be the same 12660H NEW ONE ![]()
--I decide after that to go For a moment .
.& take crazy-scan work & saving report
with AUTO EXPORT...NO TP will escape again !!!
unfortunately I can't do spectrum after that ![]()
12543H -39.61dbm ....14:03-02/01/2018 A NEW ONE
12660H -39.86dbm ....15:30-02/01/2018 AGAIN
12201H -32.4dbm ....15:46-02/01/2018 AGAIN
12279H -32.11dbm ....15:51-02/01/2018 AGAIN
12360H -33.93dbm ....15:59-02/01/2018 AGAIN
12441H -32.71dbm ....16:04-02/01/2018 AGAIN
12159V -31.49dbm ....16:20-02/01/2018 AGAIN
12240V -31.52dbm ....16:24-02/01/2018 A NEW ONE ![]()
....TO BE CONTINUED!
12321V -32.3dbm ....16:31-02/01/2018 A NEW ONE ![]()
after that no thing new ![]()
scan continue & non stop since 14:00 pm pass n°206!!!!
I suppose they doing test in China
all test stop around 18:00 pm in algeria time
in china it is 18+7=01:00AM!!!! ![]()
Alcomsat-1 is below horizon from China.
Gunter's space page says: "Two ground control stations have been built, one in Medea and the second in Ouargla, which will control the satellite. They will be operated by an Algerian staff that has been trained in China."
But probably there are some Chinese commissioning engineers present as well.
Very good explanation ![]()
may be the Algerian engineers contact with the Chinese engineers with internet or some thing else in ""the reel time!!""
so that's why the tests stop very earlier !
& THEY said Alcomsat will be run in 3 or 6 month in Algerian television !! very long time !
https://www.youtube.com/watch?v=ZLi6b3JLCjQ
https://www.youtube.com/watch?v=9GNbjqM4X6k
test on
12320h
hello toufik
yes there is test now
12505V tray to increase but an other one increased 12320H !
toufik your snapshot doesn't show up to me !!!
now two test at the same time 12320H &12630V ![]()
test
12630 v
test frequency, location of western balkan
/edit by qwer: Uploader files disappeared.
thank you toufiksmso&milan58 ![]()
so the footprint of ku-band is big than Algeria but also west-europe ! ![]()
the test is very long this time
& still the same ! 12320H &12630V after 160 pass !!! ![]()
