test off
24.8°W Alcomsat-1
yes toufiksmso tests stop early to day (from 10:15 to 13:05-Algeria time)
& you have a third tp 12520V ???!!! I don't have it in my area !!
I continue until Pass 400 , no thing show up after pass 209 !
[Blocked Image: https://e.top4top.net/p_733ksnh21.gif]
to day test are very fast
12320H at 9:20 gone quick !
12520V at 9:40 gone quick ! A NEW one !
12540V at 9:41 gone quick !12671V at 9:48 gone quick !A NEW one !
12698V at 9:46 gone quick !A NEW one !
12551V at 10:15 gone quick!A NEW one !
for the moment there is no test !!! -
also to day ;
12630V at 10:23 gone quick !
12710V at 10:28 gone quick !A NEW one !
12710V at 10:31 !A gain !
12707V at 10:34 gone quick !A NEW one ! & a smal pick of 12707H!!!! at the same timemay be 12707 & 12710 are the same tp ??
Thank you for continuing to scan today, flie!
Yesterday evening you posted an animated GIF, you also have one later today? -
hello hvdh
it's plusure for me to keep scanning !!
yes I will tray to make an other to day
I don't have a program to make this gif from 400 Pass !!!
so I use the site web : GIFMaker.orgthere is also today :
12575V at 11:19 gone quick !A NEW one !
12653V at 11:26 gone very quick !!12725V at 11:32 gone very quick !A NEW one !
12749V!!!! at 11:34 gone quick !A NEW one ! & not strong pick !?-scan is pass 174 ! & no thing new happen
Unfortunately the scan freeze in pass 292 at 16:10pm
& I wasn't there !But it was tested in :
12749V!!! again at 15:02 gone quick !
12161V again at 15:29 gone quick !12239V again at 15:41 gone very quick !
& a smal pick of 12239H appears again after second at 15:42 gone quick !12239V again at 15:45 gone very quick !
all Test TP of yesterday with fast motion
292 PASS CRAZYSCAN
/edit by qwer: LINKS disappeared (01.08.2020).
test on
12660h -
12660v
12160v
12260
12360 -
12240 not 12260
hello toufiksmso
Yes, the tests were also today but not for long12662H Again ! at 09:30 & gone !
12161V Again ! at 09:41 & gone !
12240V Again ! at 09:48 & gone !
12360V Again ! at 09:54 & gone !12533V at 10:38 & gone quick ! may be a new one ?
12731V at 10:41 & gone quick!may be a new one ?
12611V at 10:44 & gone quick! may be a new one ?
& a smal pick of 12611H appears after minute!12611V again !! at 10:51 & gone !
....to be continued
a smal pick of 12611H appears Again ! at 11:05 & gone !
12601H at 13:17 & gone, quick ! may be a new one ?
12722H at 13:19 & gone, quick ! may be a new one ?
& here some thing strange !
may be they want to build 12601H again !!
12587H at 13:33 & gone, quick !
12608H at 13:35 & gone, quick !also here there is some thing strange ????
12704H at 13:42 & gone, quick !
12728H at 13:43 & gone, quick !
12749H!!! at 13:45 & gone, quick ! -
also this day:
12601H again at 13:49 & gone !
A small pick of 12601V at 14:14 & gone quick ! may be it is new!! but after a minute 12601V return again !! & again at 14:2312722H again at 14:33 & gone ! & return again at 14:37
12601H again at 15:04 & gone !
12749H again at 15:28 & gone !
12630H again at 15:49 & gone !
also today :
12722H again ! at 16:16 & gone, quick !
12630H again ! at 16:21 & gone, quick !
12601H again !! at 16:25 & gone !
12160H again at 16:57 & gone, quick !
12480H again at 17:02 & gone !
12660V at 17:29 (may be this is new !)
& after a minute there is a smal pick of 12660H ;all gone !!12540V at 17:45 & gone, quick ! (may be this is new ?)
after that test off
New RECORD ! 580 PASS CRAZYSCAN
to day tests not a lot like yesterday!
there are :
12524V at 10:09 & gone quick!
12550V at 10:11 & gone quick!
12635V at 10:19 & gone quick!
12660V at 10:21 & gone quick!
12686V at 10:22 & gone quick! -
yesterday Test TP & also to day test TP in fast motion
Thank you flie & toufiksmso, for all the
Easy too see in the gif's, how a transponder is switched on (bottom noise), then several carrier frequencies are tested.
So what we've seen so far:
12160 H/V
12200 H/V
12240 H/V
12280 H/V
12320 H/V
12360 H/V
12400 H
12440 H
12480 H
The above is 15 * 36 MHz. Still three V transponders are missing, right?12540 H/V
12600 H/V
12660 H/V
12720 H/V
The above is 8 * 54 MHz. Band 12.5...12.75 GHz is completely occupied.I wonder if there will be more...
