56.8°E WGS-8 (Incl.)
  • I think, I am not wrong with the satellite name.
    Sband, can you confirm this one ?
    nothing else than a spike ( beacon ?) on 7405 L
    - Promax TV II+ - SMR1224EL x2
    - ASC1 X2 - RC2000C - EGIS - LNB Changer
    - 76.5°E <> 65°W
    It's either behind or close to trees. I might just be able to see it with the 1.2m but the X band kit is not winterised (nor am I). I'll try some time. Does anyone else have X band operational?
    Ku wide band: corrugated conical feed, 1.5dB NF LNA, Ku (Standard): Octagon OSLO mod for C120 & ext ref Prodelin feed.
  • Thanks S-Band for the feedback.
    Sato (Peon/Onaclia) is also X band equiped, but rarely online on this board (unfortunately).
    - 76.5°E <> 65°W
    Is this one a possibility? http://www.n2yo.com/?s=26575 aka DSCS-3 12 on hvdh list. It might have been close to the geo arc at the time of your post
  • I´ve tried to find this position - not sure about...
    Probably WGS-9 now? Only spectrum on linear feed and 1,2m.
    Ku-band LNB: Invacom SNF-031
  • It's still not clear if Feedsat received DSCS-3 12 (inclined 6.3°) or WGS-8 (non inclined) back in 2018.
    If you read this Feedsat, do you remember if the satellite was inclined?
    Meanwhile, DSCS-3 12 moved to 134.3°E, and WGS-8 moved to 149.8°E.
    Indeed qwer, we have WGS-9 (non inclined) at 56.8°E now.
    Does your spectrum have peaks coming from that direction, or are these just "background" peaks?
    Since 56.8°E is so close to 60.2°E (WGS-2), WGS-9 might be an in-orbit spare at the moment.
  • Probably peak on 7625 L - but had to be confirmed... :72:
