Scan today using 1.2m with linear V feed. I think I have the correct satellite. Can anyone else see the same?
03.1°E Eutelsat 3B
Hi s-band,
checked this position today with an "Inverto KA IDLW-TWNLRA20-D212O-OPP" on my fix CAS 120 (7.0°E in focus).
CrasyScan shows the wrong polarisation for that LNB, so correct polarisation is here circular left.
All locks are GS:
19730 L 45000 DVB-S2
19787 L 45000 DVB-S2
19987 L 45000 DVB-S2
20044 L 45000 DVB-S2
PS: deleted my earlier posts in this toppic - showing a scan with an "broken" LNB (scan).
/edit by qwer 11.01.18: Started a new toppic in GS forum, including s-bands previous report.
CrasyScan shows the wrong polarisation for that LNB, so correct polarisation is here circular left.Okay, installed today a coaxcable on my TBS 6925 "LNB out". From this "way" in "LNB in" from my TBS 6983. Now showing correct polarisation with CrazyScan.
Of course not new "trick" - showing already by dreamsat in some reports earlier.Scan of the day in circular left. No changes.
Different ratios between the two pairs here. Different beams?
Slant linear polarisation -
Hi s-band,
my evening scan in circular left.
I can confirm: First pair with lower signal.
19730 - Left - 44990.474
19787 - Left - 44990.571
19858 - Left - 44990.362
19915 - Left - 44990.546 -
Even with a weak signal , 19857 & 19915 have left I think.
Just my circular left scan (fix 1,2m dish, multifeed). I can confirm, what Feedsat wrote.
Just another scan, but no changes here.
Lockable: 19729 L, 19787 L and SR 45000
Original von KooLy
19915 - Left - 44990.546Hm, I just want to update the Ka list.
Could it be possible that your scan, KooLy, was in circular right (according changed polarities for your used LNB)? You told me already in another toppc for KA-band C. But it is strange, because same results in circular left in european countries...
Circular left scan.
20021 L 40000
20139 L 40000
/edit: correct LOF now.
Just one more test - changing dielectric plate position...
19728 L 40000
19785 L 40000
Todays signal check.
First try here - nothing new appeared.
Changing plastic plate position now... polarisation must be checked next...
Getting both in circular left with Inverto Twin WHITE Ka Circular Dual Polarity LNB on OPPOSITE POLARITY!
19728 L 40000
19785 L 40000
Today's scan on LHCP. This looks different to before as there appears to be transponder noise.
There is also data in transponders from 18.4-19.7GHz see 03.1°E Eutelsat 3B
No changes here - just my december scan.
Just my circular left scan - but no changes since december scan above.
