ZitatOriginal von Afreaka
3677 R is a little bit stronger now.
Need 0,5 dB more...please!!!
Okay, I will pray for you...
(...not done for german footy team - I swear...)
Found something here on
3676 R 28067 DVB-2 8PSK ACM
15 Channel on PLP 1 but no video and audio
Plenty of PLPs.
Not so much understandable for me .... sorry!!
Plenty of PLPs.
On MIS 2 - PLP 1
Nine channel on and wiewable
and MIS 3 - PLP 1
Novela E
and MIS 4 - PLP 1
Fox Sports (no video decoding even looks like clear - using DIVX
Plenty of PLPs.
Now I cleared it
all channels on and clear except BBCW and KUNG FU.
I need select only one. Surely direct show connections problem!!
...And finally picture including all channel in the packet ... Total of 26 channels; two of them are possibly encrypted...
Good news! 3676 R 28070 is so strong today, I have a lock on this tp. MIS1,2,3,4.
I was waiting since months....and finally I got some channels on SmartDVB (not all FTA). I´m so happy
here some screenshots
edit:
encrypted:
MIS 1, PLP 1: RTP Africa, TVI Intl., ST Sports Life, Baby TV
MIS 2, PLP 1: AMC Movies, Panda Biggs, Afro Music, Star Plus
all other 32 channels FTA - totally 40 channels in this package
Reception is even possible with "Edision primo IP" receiver from the couch
Great Afreaka!
Here are my results today.
What antenna you used for this transponder?Thanks
For 10°east, I use a 240cm PF fix dish (6 panels from China) with homemade dielectricum.
3676 R 28070
There is new content on MIS2 PLP 1. All 5 channels are in HEVC H265 (I have problems with Smart DVB, but couch receiver Edision primo IP 2 can handle it)
On MIS1 PLP1 a lot of channels are blackscreen (see FS).
3676 R 28070
MIS1: BBC Wnews PTM is active but not the content (A/V)
MIS2: PLP1:
MIS2: PLP2
PMT but no content at the moment
Hi Feedsat,
the new channels were on some minutes before...I think they are testing.
now on 3676 MIS2 PLP1
Disney Junior & Disney Channel H264
all other channels H265 (STV not running)
The mux changed frequency and SR: now 3671 R 34778
MIS 3 left (always empty before)
On MIS 1 some channels not running, only ID
On MIS 2 PLP 1 (see screenshot) some channels in HEVC, GLOOM is in HD, but encrypted now. Some channels not running, others only audio...and some are fine!
Again on old parameters 3676 RZ 28070, but very strong signal. 150 cm Antenna should be enough now.
Greetings
Fidu
Yes, the mux is "stronger than ever"...i have 11,7 dB
But...since today I have no clear picture. Maybe they have problems or changed transmission mode. In crazyscan nothing changed. On MIS 1 IDs are now "CH101" (this is TVM f.e.)...no names
edit:
added screenshots MIS 1 PLP 1 IDs, TVM in Smart DVB
Thanks, so thats the reason I got only errors when I tried to read the stream with enigma2. Lets hope it will come
back.
3676 R 28070
only 1 channel FTA: "TVM Mocambique" on MIS 1 PLP 1
"TVM" - encrypted again (Conax)...no FTA channels in this package
Checked this tp (3675 R) again after a long time with Edision primo IP rx
SR is now 33900, 15 channels found in scan, all are FTA
more details...
3675 R S2-QPSK 4/5
MIS1 (PLP1) & MIS2 (PLP0) active. All channels on MIS1 are fine & FTA with SmartDVB, but channels on MIS2 can´t be read
