24.8°W Alcomsat-1
  • how it is possible ?
    No thing strange to me here !:25:
    It's normal for you,you're in the center of the spotl,but for me it is,however,surprising,because although you have strong signal on all transponders, of all only 12360 H I can lock in my area,and still with strong signal,located at a great distance from the edge of the footprint.
    For this reason I said that it is on a European spot,although we know that the satellite has only one beam.
    Regards :3:
  • signal tonight ...
    1=12159,H,30000,23,2 ;16.4 (9.78) dB; 19:50 20/5/2021
    2=12230,H,15910,34,1 ;16.6 (11.14) dB; 19:50 20/5/2021
    3=12248,H,12510,34,1 ;15.2 (9.74) dB; 19:50 20/5/2021
    4=12359,H,30000,23,2 ;15.4 (8.78) dB; 19:50 20/5/2021
    Just my scan in this range. No big signal for me on 12360 H 30000 2/3 DVB-S2 8PSK.
    No big changes here.
  • In my area, a somewhat better signal at 12360 H, but weaker on others :88: I would have preferred it to be the other way around.
  • signal here :3:,
    El Barlamaniya chanel added to 12159,H
  • 12360H in same beam / satellite? Currently 15.2db and stays around 14-15db all day (2.4m + SF8008)
    Others 12160H, 12230H and 12250H signal is 7-9db at night, but in the morning signal fades away.
    3m 53E - 8W, 2.4m 68.5E - 47.5W
    Octagon SF8008, Edision OS MIO
    Western Finland (63N 22E)
  • ocean
    Here the signals are the other way round.
    The 12360 H is here at about 7dB, the 12160 H, 12231 H and 12250 H are at about 15dB with 2.2m, even in acute rain.
    Perhaps someone can say something more precise about these signal differences at the respective locations (in northern Europe with ocean and central Europe with me), regarding different beams? I do not know.
  • bei mir von 12359 H keine Spur
    No trace of 12359 H in my case
  • aktuell bei mir auch nicht mehr
  • I´ve observed 12630 H from southwestern Germany (2.2m) during daytime... quite stable.
  • Etwas Geduld :123: dieser Vogel ist schon nicht ohne :22:
    Genau, ich musste noch ein paar Schritte nach Osten fahren, dann wahr er da :3:
  • mit IQmonitor habe ich geschaft ein schwaches Signal mit richtigen Daten zu bekommen
    With IQmonitor I managed to get a weak signal with correct data.
  • So schaut es aktuell bei mir aus (bei leichtem Regen)
    58 Datenkanäle
    Einmal editiert, zuletzt von Suedschwede () aus folgendem Grund: Nachtrag: Datenkanäle
  • Ich mache hier gerade ein aktuelles OpenATV7.2 für die SF8008 zurecht und habe noch mal schnell nachgesehen, geht so.
  • Früher als gestern 9.00 statt 10:45 , habe ich 0,5dB mehr bekommen, vielleicht noch früher wäre besser ??
    Earlier than yesterday 9:00 instead of 10:45 , I got 0.5dB more, maybe even earlier would be better ??
