Yep, +2 more one hour later. But that´s all from here.
07.0°W Nilesat 201
7.0W_Nilesat 201 scanned with IQmonitor. The merit of the application is that the weak signal is highlighted,but of course it cannot fill the useful signal.
12149 H 27500 3/4 DVB/S
No signal at my place -
Original von pawelwa
No signal at my placeI'm sorry you don't have a signal on 12149 H. But I find it curious when I see on your spectrum that you have only signal on three transponders,when you should have other transponders on Nilesat even if they are unlock?How come they weren't found by Crazyscan?Why do you have this gap in the spectrum?
Regards -
Hi Satesco I live near to pawelwa around 90km (In a straight line) and my spectrum look the same. Those three transponders on Pawel screen comes from E7WA, not 201.
Best what I can get from Nilesat 201 is this spectrum attached
Date of this screenshot: 2016-03-25, 23:13
No chance to get this bird in Poland -
Thank you Tomek22 for stepping in and reinforcing what pawelwa was saying.What intrigues me the most after you posted your spectrum is the existence of the three frequencies on this satellite that you receive in your area,and the rest is missing?!
Logically they should also not be receptable,but if we think that over the years we've encountered enough anomalies in other positions, then perhaps I wouldn't be surprised.And yet,how come the three frequencies appear on spectrum and others don't?
That really is a question that can possibly be answered if someone with an antenna even bigger than 2700 that our colleague Pawelwa used?Of course I'm not sure a larger antenna could help clarify this weirdness.
In my area,the signal on the three frequencies our colleague caught is almost nonexistent on my spectrum(see my spctr below).
I don't know how the signal from Nilesat manifests in every area,but in my area it is stronger during the evening/night.
Regards -
...What intrigues me the most after you posted your spectrum is the existence of the three frequencies on this satellite that you receive in your area,and the rest is missing?!
...And yet,how come the three frequencies appear on spectrum and others don't?...Hi satesco,
according your high-range spectrum above, you can´t get MENA beam from Eutelsat 7 West A @7.3°W. But you "get" this position in low band, as you reported earlier. Also you can "get" NWA beam from Eutelsat 7 West A @7.3°W, as I can see today.
According scans above from Tomek22 and pawelwa, they can´t "get" ME beam from Nilesat 201.
I can "get" both beams from these different satellitepositions at my place, of course not all frequencies as you can see im my reports above or in the specific toppics.
I can confirm, Nilesat 201 is stronger during the evening/night, as I reported...
Best regards
qwer. -
Just a scan from my place. All DVB-S signals lockable at this time - weakest signal: 11766 H.
New here since 16.10.2020, reported by M. Razzouk on FlySat:
12303 H 27500 5/6 DVB-S, Nilesat package
/edit: best signal in DVB-S2 (FEC 3/4) - but under lock:
12130 V 27500 3/4 DVB-S2 8PSK, Oman TV package
I changed C band LNB to KU band set (Inverto black pro flange+invacom C120 feedhorn) on my 1.75m dyras dish.
The best singal daily between 20-23 CET, peak at 22:00. Before 20 and after 23, there is no signal, except 12149H. This is good signal all day.
So here is my best result around 22:00 PM CET clear sky/full moon:
11727H no lock
11747H lock (limit)
11766H lock (limit)
11785V lock (stable picture)
11804H no lock
11823V lock (stable picture)
11843H lock (stable picture)
11862V no lock
11881H no lock
11900V lock (stable picture)
11919H no lock
11938V lock (limit)
11958H lock (limit)
11977V no lock
11996H no lock
12015V lock (stable picture)
12034H lock (stable picture)
12054V lock (limit)
12073H no lock
12130V no lock
12149H all day okey
12207V lock (limit)
12226H lock (limit)
12284V no lock
12303H no lock (checked only today cloudy)
Great result chucky!
In the evening hours two DVB-S2 frequencies with FEC 2/3 and 8PSK are lockable: 11862 V and 12092 V.
Before lock...
12207 V has left.
(12188 H from Eutelsat 7 West A @7.3°W has left, too)
Scan at best time - some more TP have left.
/edit: 12130 V up to 7.5dB under lock at this time.
Current situation on Nilesat 201 - midnight scan.
I had to try DVB-S2 frequency "12130 V" next again, reaching 8.0dB, but not locked on all my TBS-cards...
/edit: and locked - just before midnight (on TBS 6925) - too bad for content.. my first 8PSK 3/4 locked frequency
...last scan is from 8.00 a.m. (21.02.2021)
Big thanks feci01, great scan - (nearly) everything locked! Your scan is +1.5to+2.5dB
Todays scan during best time (at my place)... waiting for the lock on the only possible S2 frequency again 12130 V (7.9dB).
11746 V is the weakest DVB-S signal (still unlocked 4.3dB). In attached file you can see my earlier mid-day signal-minimum scan... about 6 frequencies are lockable 24h (when there is no rain
Locked again this evening... 12130 V (no chance for content right now)
Not my catch (not checked yesterday
)... khaled Star on FlySat:
11862 V 27500 5/6 DVB-S
12092 V 27500 5/6 DVB-S
