Davon kann ich hier nur träumen
07.0°W Nilesat 201
I must admit that the 6902se card has helped me lock some muxes at 7.0W for the handicap of my small 1.5m antenna.
Instead, IQmonitor gave me a spectrum with many transponders locked with the tbs6983 card.
I'm almost convinced that with the 1.8m antennae, I could lock and see more transponders, maybe all(?)
Slightly better reception ( from my last scan ) due to weather conditions. I can see also and some tps from 8W ( > 12500 )
Here are my Scans for Nilesat 201-301 from my QTH with current difficult setup
12072 H - Near the lock
12130 V - Near the Lock
12283 V - Far away from lock
Which of the antennas in the signature do you use? Thanks
Hi satesco
I use 4.2Mt
Now,
12072 H - Same situation
12130 V - Close to the Lock
12283 V - 2.9 dB to the lock
My best (unlocked) S2 signal is with 0.5dB under LM at scan time:
12130 V 27500 3/4 DVB-S2 8PSK
Yesterday 22.00 CET more near to lock 12130 V... but I was too to tired....
...and 11747 V via manual lock on TBS 6522...but too low signal (0.5dB more needed) for showing content.
Attached DVB-S locks via TBS 6522 scan.
