For stats
10742 V 2893 3/4
10760 V 2480 7/8
10.0°E Eutelsat 10A (OLD POSITION Feeds>Ku)
UHD Feed 11595 V 33333 2/3 16APSK
(4 X H264)
Watford Vs Manchester United I think -
Can you check 11056 H 9875 3/4
Locked ? -
Locked ?Hi Feedsat,
tried, but can´t get a lock atm.
(Skew not perfect)
OK, thanks.
here ,even with 12dB, no lock
this is not the 1st time, few days ago it was @ 7°E.maybe Goldcode ? (they don't use root or combo, only gold).
PS: not in NS3/4 or S2X
If someone can lock this, you're welcome to share your report
I think, 11056 H has left now.
/edit (10.53): and on again! (sorry) But according Constellation it looks like 8PSK now.
My signal
Original von pawelwa
My signalThanks Pawelva, unfortunately, probably not the same uplink .
My signal was good for a lock in 8PSK 3/4 (12dB)Next time, we will try again.
thanks guys for checking
OK, this weird signal is now active on 11080 H 9875
not recognized with 6522
if you can, check this right now.
maybe my signal is too weak - or PLS ? -
No Lock here on 11081 H (TBS 6983).
Not tried: PLS...
maybe my signal is too weak , but I am not sure.Hi Feedsat
NO LOCKED at my place. -
Okay, finally locked 11081 H on (13.9dB). It looks like encrypted feed.
Update modulation says: DVB-S 3/4
Okay, finally locked 11081 H on (13.9dB). It looks like encrypted feed.Update modulation says: DVB-S 3/4
Now in 8PSK lockable.
If I mark "update mod. info" it shows DVBS ,too.
Thanks guys for your feedback
yes no problem now
but I'd like t know what happens with the previous signal
Hi Feedsat,
you´re right, now this feed (11081 H) has changed in 8PSK, still on and no problem to lock right now.
My first report was not with 8PSK, but with same content, according ID and Pids. -
one more weird 11635 V 7120
signal is strong enough for a lock (usually)tested with all the modulation type I can demodulate
S2 S2X NS3 NS4 -
Arrgh! I haven´t seen your post earlier, now nothing to lock (11635 V).
RUS-030
11163,H,7248,56,8PSK -
11135 H 22500 3/4
EMA 2016 TC (MTV EMA Test ?) -
rare TV5Monde feed (French) from Madagascar
10770 V 2400 3/4PS: UEFA Celtic Vs Barcelona on 11684 V 13333 3/4
