10.0°E Eutelsat 10A
    Just to show content/signal at my place from Suedschwede scan above:
    3651 R 24165 5/6 DVB-S2 8PSK, StarTimes TV package - in clear
    No other changes in spectrum.
  • Still bad conditions. Startimes packages no lock, uganda mux no lock with 1.8meter.:33:
    Switched to my 240 cm Jonsa dish. But startimes muxes no lock. All other is ok. So operator reduced signal level strongly.:80:
    I can confirm StarTimes package on 3651 R with lower signal (according my last scan).
    C-band: 55.5°West-68.5°East ORBITRON O-16 (4,9m) / X-band: 17.8°W-60.2°E KATHREIN CAS 120 (1,2m) / Ku-band: 61.0°West-80.0°East KATHREIN CAS 23 (2,2m)
    Ka-band A/B/C/D: 30.0°W-75.0°E KATHREIN CAS 018 (1,8m) / Ka-band band A 2x KATHREIN CAS 120 fix on 19.2°E and 42.0°E
    C-band LNBs: Kaonsat, C-Panorama 13K, Norsat 8000RI C-DRO, BrasilSat LNBF AP30 PLL / X-band LNB: Norsat X1000HAF / Ku-band LNB: Invacom SNF-031, Inverto Single Flange / Ka-Band LNBs: Inverto Twin WHITE Ka Circular Dual Polarity LNB (flange), Inverto IDLK-SINL20-KAKU-OPP,MCL-KP04, Norsat 9000HX-O3B-BN, Orbital LNB1825F-1000D-WF55
    Feeds: Invacom ADF_10 + 2 rings, XMW Ka-band Feed FD9000K / Waveguide Polariser: AV-COMM / Tuner: TBS 6925, TBS 6903, TBS 6903X, TBS 6522
  • 3865 R DVB-S2/8PSK 4680 5/6 locked today.:128:
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Zur Zeit gibt auf 3876 R 2000 2/3 QPSK2 ein Transponder mit richtige power
    ob es lang dauern wird ?????
    Currently on 3876 R 2000 2/3 QPSK2 there is a transponder with proper power.
    whether it will last long ?????
    It´s from position 12.0°E. :3:
    Du meinst Sicral1B ?
    oder welche sat ist auf 12° Ost ?
    bin ich 2 Grad daneben ? ......
    habe gerade gelesen blagovest 4
    Wohaa ich muss aufpassen
    Den Blagovest 4 habe ich auch im Spektrum von 17.0° Ost mit 4.9m... :77:
  • 3835 R 1650 5/6 LXP (Loveworld XP)
    No Signal Here in My Home ..!
    To 103.0°E
    Still there.
    Scan. Probably new here: 3691 L 1100 2/3 DVB-S2 8PSK, URHC TV :133:
    Just a new scan in ´22.
    Some changes - not new N Stanislav on LyngSat 09.02.2022:
    3860 R 4040 2/3 DVB-S2 8PSK, Télé Tchad
    PS: Ignore 3877 L - it´s from strong 12.0°E position.
    Just a complete scan - nothing new appeared in S2.
    On again: 3778 R New World package.
    /edit: changing parameter: 3721 R 3600 3/4 DVB-S2 QPSK
    New:
    3788 R 4042 2/3 DVB-S2 8PSK, Télé Tchad - still on 3680 R
    Just another scan here after more than 4 month, using TBS 6903. Nothing changed according last scan - three active feeds at scan time.
  • Scan, probably new here:
    3803 R 1500 3/5 DVB-S2 8PSK, CIS TV [reported as circular left on FlySat by khaled Star ]
    4003 R 1417 3/4 DVB-S2 8PSK, Télé Tchad
