STEREO-A (Heliocentric)
  • https://stereo-ssc.nascom.nasa.gov/where.shtml
    https://stereo.gsfc.nasa.gov/
    1st deep space capture on X band, 8443.555MHz (approximately). Using a plumbing component feed with the 7.5GHz LNA on a 1.2m dish. It's not a great system with a sky/ground noise figure of ~3dB. About 10dB S/N in 0.5Hz. 9125MHz LO inverts the spectrum so the doppler change is downwards.
    2.5Ms/s, decimated by 64, 131k FFT
    Ku 12-18GHz: corrugated conical feed, 1.5dB NF LNA, Ku (Standard): Octagon OSLO mod for C120 & ext ref Prodelin feed.
  • This evening's signal. The feed was improved slightly (2.2dB sky/ground NF now) but the changed vertical scale makes it look better. 100Hz/div horizontal scale.
    Edited 2 times, last by s-band ().
  • Tonight's plot. I need to fix the LO drift, it is greater than the doppler change. The frequency is reducing which would be seen as increasing frequency on my plot as the LO is on the high side.
  • Not such a good signal but frequency is locked now.
  • 9450MHz LO
    8443.5607MHz
  • Today's signals, he first whilst data was enabled and the second with data off just after the end of transmission to Madrid.
    RX frequency in file name. That is down-converted to 421.4MHz with spectral inversion.
  • Plot of STA whilst talking to Madrid today. 1.2m dish, ~1dB NF, modified Prodelin feed.
    The signal level on Madrid's 70m dish (DSS63) at the same time was -118dBm. The distance today is about 194 million km vs. 246 for the earlier plots.
    Edited once, last by s-band ().
  • Probably not transferring data so a stronger carrier today.
  • Probably not transferring data, 205.7 million km, 9GHz LO, 1.2m dish.
  • Not transferring data, 184 million km, 1.2m dish.
    Probably the most reliable craft to use as a beacon.
  • In communication with Madrid DSS63 at -118.5dBm, 182.5 million km,
    9GHz LO, 1.2m dish
  • In communication with Madrid DSS63 at -117dBm, 176..7 million km,
    1.2m dish
    RX Tuned to 8443.551MHz, IF frequency 21.4MHz with frequency inversion. Upper plot not inverted.
  • In communication with Madrid DSS65 at -122dBm, 149.8 million km
    RX Tuned to 8443.570MHz, IF frequency 21.4MHz with frequency inversion. Upper plot not inverted.
  • STEREO-A X-Band downlink from today.
