Today I repeated the "jump to frequency" function on the 68.5E satellite and now there are no more vertical lines at the beginning and end of the jump The first test was the HR spectrum of the whole band without my intervention, it took a very long 4555 seconds
After that, I repeated the same, but first with the 6MHz classic spectrum to which I added the HR spectrum. Based on a very clearly visible RF signal, I skipped three times with the "jump to frequency" function and accelerated the whole process to just 1545 seconds
Question for our friend Wanderer : Is it possible to extend this function by an automatic skip every time the RF signal drops to the noise level in calibrated mode?
IQmonitor tool
Original von Lambda
Hi Lambda!I answer your question:
Yes you can.
Moreover, this has already been implemented in the program, but is not yet available for a wide range of users.
When people get used to HR spectra, this option will be open to all users.I have worked hard to eliminate the vertical sticks that appear if the transponder list is not cleared before receiving the HR spectrum.
It seems to me that I have eliminated this shortcoming.
Tested on skipping the frequency range of the side 9 ° E when receiving 10 ° E on a small antenna.
First, I registered the RF spectrum, and then the HR spectrum with a “manual” pass of unwanted frequency intervals for subsequent analysis.
Then, using FeedReport, it “clicked off” the transponder peaks, including subthreshold ones.
I found a tiny little one with SR = 256 kS/s and locked the radio broadcast. :85:
See here and test at PMHealth and success!
what a perfect ultra-spectrum I see here !!!
thank you very much Strannik for the Excellent Remark
so with a good calibration we can see very low signal ! But this need a very Expert eye !
about 19706 L apparently is a beacon , I tray also feedreport for other Transponders (A,B,C,D,5,6,7,8) there is info ; they are very far from me
About Transponder (2,13) I think they are anomaly from Triax-Twin-Ka lnb -
Hi Lambda
I also use RF-scan before H.R.Spectra because it is easy to me too and to chose Noise value as I want ..this makes also the vertical line appears to me too
I don't tray to inverse operation yet (H.R.Spectra before RF-scan)About ABC 4T2 and TSreader they are work with me with out problem Even MPC-BE but I use MPC-HC ! I use this parameters :
It doesn't mater if you use slash or backslashJava=C:/Program Files (x86)/Java/jre1.8.0_161/bin/javaw.exe
TSRLite=C:\Program Files\COOL.STF\TSReaderLite/TSReaderLite.exe
TSR=C:/Program Files/Cool.stf/TSReader/TSReader.exe
VLC=C:/Program Files/VideoLAN/Vlc/vlc.exe
4T2ContentAnalyser=C:/Program Files/ABC/4T2 Content Analyser/ABC4T2ContentAnalyser.exe
TrEdit=C:\ProgramData\CMUV\DVBViewer/TransEdit.exe
MPC-BE=C:\Program Files\K-Lite Codec Pack\MPC-HC/mpc-hc.exeHi femi
with TBS6903X I prefer to use Direct_BLindscan with :Band18&Step12 with this parameter IQmonitor is Faster ,Unless if you want to use Deep search in this time I use also IQmonitor Dircect_BLindscan with :Band5&Step2 ...in both the result I think it better than using Blindscan2 with Crazyscan (Band18&Step12 faster ! and with Band5&Step2 more Transponders you can get ! but you have to be patient !)It is preferable to not use H.R.Spectra with TBS6903X or TBS5521 Unless if the Streamreader change in the future
It is better to use the H.R.Spectra only with professional cards like ;TBS5927 or TBS6903 ,TBS6908 ....etc
regards
flie
Femi, Flie thanks for your instructions, unfortunately ABC4T2 and TSR Lite are still unavailable to me .. But actually it's not that important to me.
Wanderer, thanks for the quick response and even faster solution to the problem of HR vertical bars :97: My beta tests confirm that you have solved the problem
Great job as always
It may be stupid but I have one wish, sometimes during long HR searches I forget about the IQ monitor running in the background, it would be good if the signal sound would warn me that the program has finished its work -
Unfortunately at position 57E the vertical bar was repeated when selecting the "jump to frequency" function
Same satellite, no problem today
90E HR spectra
Hi Strannik
I think that you find exactly the working area of my Triax_twin-Ka lnb Using Ulta-spectrum with Expanded range with19350-20670 Mhz
regards
Test of the new TBS6903x V2 card with IQ monitor.
HR spectrum okay, only very slow.
BlindScan not working. -
Another HR test, 52.5E separate from other neighboring satellites with "jump to frequency" function
Hi PEON
Did you tray Direct-BlScan with Step18&Band12 works fine with mehttps://www.satellitescommunit…hreadid=1565&sid=&page=34
Regards
Just traying Ultra-spectrum with Expanded Range in Ku
H.R.Spectra works fine
But a part of RF-scan is missing ? -
At usual Ku Range ,Not perfect yet ...I still need practice
Regards
flie. -
Hi Flie! If you want a better result, first create a classic spectrum with calibration turned on, turn on "minimum level RF" with the same value as in the "Noise" field. Then turn on the "Add" function and create an HR spectrum...
I think your "direct Blind scan" can look better too, all your values are in the same line. Look at my result in the following picture, you will notice the difference -
Original von flie
Hi PEON
Did you tray Direct-BlScan with Step18&Band12 works fine with meRegards
Hi flie.
It's okay with a big step.
But such "aerial" scanning is not thorough.
I compared it with TBS6983. HR spectrum mode. -
Original von Peon
Hi flie.
I compared it with TBS6983. HR spectrum mode.Can you tray with Step5&Band2 ? scan time is longer but Better I think
Original von Lambda
I think your "direct Blind scan" can look better too, all your values are in the same line. Look at my result in the following picture, you will notice the differenceThank you very much Lambda
I think it better now But I can't avoid vertical lines -
My tests show that vertical lines no longer appear in version 2.4.0.5 beta. We are waiting for Strannik, to honor us with the official version...
I just did a test on 26E, I used the "jump to frequency" function five times, no vertical lines
I made a comparison of version 2.4.0.5 beta and previous 2.4.0.4 on satellite 10.0E. It can be seen that the new version does not have a problem with vertical lines when skipping frequency, but in both versions I occasionally get vertical lines even though I did not use the skip function
