IQmonitor tool
I cannot understand why you are not reading the program status bar, where you are constantly asked to double-click on the peaks of unlocked transponders?
sometimes I don't want to destroy IQmonitor's_Transpders-liste with Unlocked signals
I have to admit that my dishes are not in the perfect condition
but I do this experiment any way
and that's what make me love C-bant ;whatever if your dish is in good condition or in bad condition
you can always see something in c-band
1.80m offset VS 1.80m PF with the same LNB Panorama 13K
Test with IQmonitor pro @22°W
1- ultra-high spectrum (only locked signal)....
1.80m offset SNR.avr.H= 5.11dB ,SNR.avr.V=3.75dB
1.80m PF SNR.avr.H= 4.84dB ,SNR.avr.V=4.34dB
1-ultra-high spectrum + manual scan ( locked + No-lcked signals)
1.80m offset SNR.avr.H= 7.19dB ,SNR.avr.V=7.02dB
1.80m PF SNR.avr.H= 7.37dB ,SNR.avr.V=6.78dB
Feed-Reports ;
3747,H,47000,3/4,16APSK ----No locked
3824,V,10300,3/4,8PSK ---------No locked
4024,H,2376,3/4,32APSK-------locked!
3985,H,4000,?,QPSK? -------Unknown !
Still hard to me to read SNR from Feed-Reports
111 - Point - окошко задания номера точки отбора потока I/Q в демодуляторе
Congratulations!
Finally, you understand that the microscope is not made for hammering in nails - there is CrazyScan for that
Now you can leisurely start mastering all the wonderful features of the IQmonitor Pro program
When I work with OMIKOM, I also have this forecast field empty. It is filled only for cards with a chipset like TBS 6983
Когда я работаю с OMIKOM, у меня это поле прогноза тоже пустое. Оно заполняется только для карт с набором микросхем как у TBS 6983
First, thanks for the excellent testing of the I/Q sampling points.
Unfortunately, my assumption that the card driver - StreamReader bundle does not work correctly has been completely and unambiguously confirmed.
Analysis of constellations from various points of I/Q stream selection shows that at 1 point (from where IQmonitor Pro takes data for its analysis by default) SNR = 7.9 (8.4) dB.
At 10 point SNR = 8.3 (9.6) dB, MS is recognized
At 20 point SNR = 7.9 (8.7) dB, but MS is not recognized
At 22 points SNR = 8.7 (9.7) dB, noises are suppressed to the maximum by the demodulator, and MS is recognized.
Therefore, I will recommend the following to you:
Zitat98 - DVB-S2X - checkbox for working with transponders of this standard
99 - the I/Q constellation scale for the DVB-S2X standard is entered in the window
111 - Point - window for specifying the number of the I/Q flow sampling point in the demodulator
Check the box 98, and in the field 99 enter the coefficient 2.55
In field 111, enter point number 10.
Now try to get the HR spectrum and run a series of FeedReport definitions on it for both locked and unlocked transponders.
Publish these results on the forum,and yourself in field 111, specify the point number 22 and repeat the same actions for it.
I look forward to your results.
Good luck! -
Ha jetzt bin ich einfach Baff!
Modulation funktioniert viel besser und blindscan haut nicht einfach ab auf andere frq.
Hier zuerst Horizontal und alle starken Sender im 1. Scan alle gekriegt was kriegen kann. nachträglich gar kein einiges.
Ausser hab wieder mal etwas probiert ohne Lock auf frq 11551 : Broadcasting Transport Stream to U D P port 2103 33°0E Transponder 11552_H
ich glaube sogar meine SNR funkt jetzt
Wie wird der SNR berechnet?
Es wird in Dezibel [dB] angegeben und berechnet sich auf der Grundlage von Spannungswerten bzw. von Leistungswerten wie folgt: SNR/dB = 20 log [Nutzsignalspannung / Rauschsignalspannung], SNR/dB = 10 log [Leistung Nutzsignal / Leistung Rauschsignal].
Ich habe dich gefragt und möchte immer noch sehen:
- Hauptfenster mit Parametern;
- FeedReports von gesperrten und entsperrten Transpondern (einmal mit 10, das zweite Mal mit 22 I/Q-Stichstellen).
Verstehen Sie, ich habe alle meine Angelegenheiten beiseite gelegt und mich auf Ihr Problem konzentriert. Und ich habe keine Zeit zu warten, bis du mit dem UDP-Stream spielst
Würd' mal sagen der 12246 stammt vom High-Power Transponder des Astra 5B und nicht vom Eutelsat 33E.
Nachdem bei mir schon fake-Transponder auf Hellas Sat im KaD-Band auftraten, werde ich immer misstrauisch und klemme/stecke alles nicht notwendige immer ab.
ich weis jetzt gehts nur um meine streamreader,der nicht korrekt ist.
