IQmonitor tool
  • In my case, IQmonitor 1028 worked better in HR mode with tbs6903x, and I think I got a hopefully good spectrum.
    This time, the app locked and displayed the parameters correctly on an S2X mux. This is the first time this has happened with this card.
  • Deine Arbeit unter diesen wirklich komplizierten Bedingungen
    erfordert eine Menge Selbstverleugnung.
    Hut ab, und vielen vielen Dank. :38:
    Your work under these really complicated conditions
    requires a lot of self-denial.
    Hats off, and many many thanks. :38:
    Ваша работа в этих действительно сложных условиях
    требует большого самоотречения.
    Снимаю шляпу и большое спасибо. :38:
  • I join stephan in paying tribute to your dedication to work on IQmonitor, Yuri. :18::38:
    It's a shame we can't help more. :25:
  • Blindscan low symbol rate (12605-12612 V) at 10.0E with IQmonitor v.1028, Crazyscan and EBSpro
  • Maximum graphic resolution and HR spectrum with 6983 cards at 42.0E. HD spectrum came out better after scanning with IQmonitor 1028.
  • Hi, strannik, Hi all!
    I have two "trivial" question, please help to me.
    Firstly. I need using, the IQmonitor latest Pro version, how download? Not found the downlink me in the forum...
    Second, this article https://filatov-yuri.livejournal.com/16846.html noise reductions.
    This horn, applicate to PFA dish? If yes, how to?
    (Sorry, the my basic questions.)
    Best regards,
    SaTom
  • This horn is used on an offset dish, but you can try it on your PFA.
    look at sites to made truncated cones or rockets
    The ratio of the inner and outer diameters of the truncated cone is about 1:1.5
    Height of cylinder and truncated cone 1:1
    Everything must be electrically conductive.
    Thick sheet metal cannot be bent in a shapely manner, thin sheet metal crumples quickly, which is why I put the project on hold. Machining on the lathe would also be an option.
    strannik deleted the last versions, there was little interest and the 1.0.2.7 in particular was still very buggy, also due to the power supply in Kyiv.
  • I chose Eutelsat 33E at 33.1E to blindscan it in HR mode with IQmonitor 1028 because there are many transponders with the S2X extension, and at the same time, it also works in DVB-S2.
    Unlike previous versions, blindscan in this HR mode worked well, and I could lock them.
    I didn't understand why I got an excellent feeds report on some transponders and others, absolutely not at all, although the spectrum looks ok.
    Maybe it's inappropriate to post here, but out of curiosity, I scanned this part of the band with neumoDVB on Linux, and the scan time was only 13.50min. With IQmonitor, regardless of the settings chosen, this scan takes a very long time. But I must admit I managed to get a good spectrum. At least, I think so.
    In the meantime, I also scanned with the 6902se card in Maximum graphic resolution. Only what you see in the screenshot can be obtained.
    ...Maybe it's inappropriate to post here, but out of curiosity, I scanned this part of the band with neumoDVB on Linux, and the scan time was only 13.50min.
    satesco
    I see that for 11256H on 33E the SR is reported differently between IQmonitor in Windows and nuemoDVB in Linux?
  • satesco
    To avoid debating this topic in this thread which has another purpose, I will move it to 6903x's thread (#143)
  • Thanks to you and everyone who tests the program! :74:
    I don't have much time to write, but I carefully review your publications and it helps a lot in improving the program.
    Now I have made an automatic search for tokens on constellations in the DVB-S2X modulation area.
    Now the HR spectrum will display these transponders.
    As a bonus, transponder locking has improved, weak subthreshold transponders can be locked even in automatic mode.
  • Greetings, Yuri and other DXeers. :70:
    If this post does not belong here, please admin to move it. :68:
    I tested both the TBS6903X V.2 and V1.2. The results are the same for both cards. The latest version of IQmonitor already renders the spectrum nicely, even with this card. (It's a pity that other scanning options are blocked, but it certainly has its meaning.) I was surprised that the spectrum in CrazyScan does not match the transponder frequencies. The IQ monitor draws them correctly. The sensitivity of the TBS6983 and TBS6903x cards is approximately the same. Unfortunately, none of them reach the sensitivity of the TBS5925. :73:
    Used latest versions of CrazyScan, IQmonitor and Streamreader.
    The comparison is in the attached pictures.
    CrazyScan:
    TBS6903x: TBS6983:
    TBS5925:
    CrazyScan automatically adjusts the signal level range. In the part from 3610 to 3750MHz, I have LTE Internet interference, that's why the shape of the spectrum is like this.
    IQmonitor 1028
    TBS6903x: TBS6983:
    TBS5925:
    Einmal editiert, zuletzt von Peon ()
  • Hi Peon , :3:
    A little problem with your message
    Only one image is visible ( TBS5925) ,
    all the others are not visible.
    It is difficult to make a comparison. :25:
  • Hi Peon , :3:
    Hi Stephan, I have everything displayed, six pictures with a description. I don't know where the mistake is. :37:
  • Hi Stephan, I have everything displayed, six pictures with a description. I don't know where the mistake is. :37:
    Please, in a NEW message, re-upload these pictures using the ATTACHMENTS toolkit, without using the old links to the site and your computer :74:
    Пожалуйста, в НОВОМ сообщении перезалейте эти картинки с помощью инструментария ATTACHMENTS, не используя старых ссылок на сайт и Ваш компьютер
  • Please, in a NEW message, re-upload these pictures using the ATTACHMENTS toolkit, without using the old links to the site and your computer :74:
    Crazycan:
    TBS6903x:
    TBS6983:
    TBS5925:
    IQmonitor:
    TBS6903x:
    TBS6983:
    TBS5925:
    Is it OK now? :68:
  • Version 1.0.2.9 is not released.
