IQmonitor tool
  • Thanks for help,where are i can found last version for download?
    here you have the latest version available
    (under the current circumstances it is not fully finalised and has some problems)
    otherwise this is the last stable version
    If this is your first try with this program, I advise you to read all the instructions available in this forum before asking any questions.
    TBS5925+6983; Openbox SX6 ; Edision MIO4K ;GTMedia V8 turbo
  • here you have the latest version available
    sinon celle-ci est la dernières version stable
    Thanks
  • Blindscans Vergleich zwischen IQMonitor und Crazyscan auf 3° West im C-Band .
    a comparison of blindscans between IQMonitor and Crazyscan on 3° West in C band.
    сравнение слепых сканирований между IQMonitor и Crazyscan на 3° запада в С-диапазоне.
  • Tests with IQmonitor v.1028 and Crazyscan. (Semi)successful attempt to find and lock muxes low symbol rate with 6903x card in HR mode.
    Although the constellation is promising, the parameters are not displayed, although the signal is strong.
    These muxes are too close for the application/driver to discriminate against them.
    Tests with the same IQmonitor version in HR mode with 6983 on the same low symbol rate muxes, some manually locked.
  • ich poste mein Ergebnis hier, weil es einige kleine
    Probleme gibt, auf den verschiedenen Tabellen von IQMonitor
    wo manchmal unterschiedlich sind : z.B die dB als auch
    die Frequenzeingabe bei manuellen suche
    Ergebnis der Suche auf 34,5 West mit vielen
    sehr kleinen sr, die nur IQMonitor findet.
    I post my result here because it shows some small
    problems on the different IQMonitor tables
    which sometimes have differences between them:
    the dB value indicated as well as the frequency
    when searching manually.
    Result of the search on 34,5 West with a lot of
    very small sr that only IQMonitor finds.
    Я размещаю здесь свой результат, потому что он показывает некоторые небольшие
    проблемы на различных таблицах IQMonitor
    которые иногда имеют различия между собой:
    указанное значение в дБ, а также частота
    при поиске вручную.
    Результат поиска на 34,5 Западе с большим количеством
    очень маленький sr, который обнаруживает только IQMonitor.
  • the rest of the tables
