• For my part I have no problem with my tbs 6983 and the 1028 pro version.
    sometimes he doesn't want to start making a spectrum, but that's often a fault on my part.
    Here is my result just now on Türksat.
    Meinerseits habe ich mit meinem TBS 6983 und der 1028 Pro-Version kein Problem.
    Manchmal will er kein Spektrums erstellen,das ist aber oft ein Fehler von mir.
    Hier ist mein Ergebnis auf Türksat.
  • Win10, driver 1.0.0.7 all ok.
    But mostly I'm using the IQMpro 1.0.2.0 version if I want to save anythig
  • Dear Community,
    I have just started using IQ monitor. I read a lot, and hope that I did not do anything wrong!
    I am using versionIQ monitor 1.0.0.1 StreamReader 1.2.4.96 and a TBS 5927 with driver version 1.0.0.7.
    First I wanted to receive on Thor 0.8E the transponder on 12418 V 28000 7/8. I click on "Get Lock", after lock on "Filter", and then analyze the output via Transedit. This worked fine!
    But then, I change to 10934 H 25000 3/4. Again, I click on "Get Lock", after lock on "Filter", and then analyze the output via Transedit. The PAT lists the TS reference as TSID 5, which - when checking the NIT - lists the transponder frequency 11785 H 28000 7/8. Also, the list of services and service IDs match that transponder.
    What could be the reason for the TBS 5927 not tuning correctly? It seems that there is an offset between the transponder / frequency band commanded to be received and the actual received transponder.
    The antenna is a T90 with several LNBs and a Diseq Swtich, which works fine with a Technisat and a VU+ zero STB. So I don´t expect an issue there.
    Looking forward to your answers! If needed, I can share screenshots and spectrum scans.
    Greetings from Vienna,
    Peter
  • Hallo Peter,
    es liegt weder an dir, noch an der Hard- oder Software.
    Ich habe es schon einige Male erwähnt, dass die NIT oftmals eine Hausnummer ist.
    Vorallem im K-Band stimmt sie fast nie, da dies noch häufiger Übertragungen sind. Deine Beobachtung gibt es z.B. auch auf Helles Sat (39E).
    Die NIT wird in den Datenstrom eingefügt. Allerdings machen die Betreiber dies häufig nur einmalig. Wird nun ein Transponder an anderer Position/Band ausgestrahlt, geschieht das oft mit der ursprünglichen NIT. In einigen Fällen sucht man die NIT auch vergeblich.
  • Guten abend,
    Ihr habt vielleicht bemerkt, dass wir seit etwa 1 Monat nichts mehr von Strannik gehört haben und dass er im Forum nicht mehr aktiv ist.
    Keine Sorge, Strannik geht es gut, es ist nur sein Computer, der nicht mehr funktioniert und natürlich die dazugehörigen Internetverbindungen.
    Er versucht zu retten, was zu retten ist, und wieder mit dem Forum in Kontakt zu kommen.
    Ihr müsst geduldig sein, es kann einige Zeit dauern.
    Good evening,
    You may have noticed that we haven't heard from Strannik in about 1 month and that he is no longer active on the forum.
    Don't worry, Strannik is fine, it's just his computer that won't work and of course the internet connections that go with it.
    He's trying to salvage what he can and get back in touch with the forum.
    You need to be patient, it may take some time.
    Добрый вечер,
    Вы, наверное, заметили, что от Strannik'а не было вестей около 1 месяца и что он больше не активен на форуме.
    Не волнуйтесь, со Strannik'ом все в порядке, просто его компьютер не работает и, конечно, интернет-подключение, которое с ним связано.
    Он пытается спасти то, что может, и восстановить связь с форумом.
    Вам нужно набраться терпения, это может занять некоторое время.
  • Ein Vergleich zwischen den verschiedenen Versionen von IQMonitor ( 2407; 2208Pro und lite ) bei einem schnellen und einem hochauflösenden Blindscan.
    A comparison between the different versions of IQMonitor ( 2407 ; 2208Pro; lite ) during a fast blindscan and one in High resolution.
    Сравнение различных версий IQMonitor (2407; 2208Pro; lite) во время быстрого сканирования вслепую и в высоком разрешении.
  • Hallo Stephan94,
    wenn du Lust hast, lass es einmal mit dem streamreader 1.2.5.199 laufen.
    Ich vermute, dass die Zeiten dann etwas länger werden, zumindest hat sich dass bei den tests für strannik bezüglich der TBS6903x abgezeichnet.
  • Hallo Stephan94,
    Guten Morgen Femi ,
    es bringt absolut nichts, die dB-Werte werden nicht angezeigt
    it does absolutely no good, the dB values are not displayed
    это не приносит никакой пользы, значения дБ не отображаются
  • Es liegt an der light 1.0.0.1
    Die 1.0.2.0 machte überhaupt Probleme mit dem Spektrum. In der ini standen noch die Daten für den 6903x-Test.
    It's because of light 1.0.0.1
    The 1.0.2.0 caused problems with the spectrum at all. The data for the 6903x test was still in the ini.
    Это из-за лайт 1.0.0.1
    На 1.0.2.0 вообще были проблемы со спектром Данные для теста 6903х еще были в ini.
  • ein weiterer Vergleich
    zwischen den Versionen 2407 und 1028 Pro
    dieselben Einstellungen
    die 2407 mit STR 1.2.4.100 ist deutlich schneller als die 1028 Pro mit STR 1.2.4.137
    another comparison
    between versions 2407 and 1028 Pro
    same parameters
    the 2407 with STR 1.2.4.10 is significantly faster than the 1028 Pro with STR 1.2.4.137
    другое сравнение
    между версиями 2407 и 1028 Pro
    те же параметры
    2407 с STR 1.2.4.10 значительно быстрее, чем 1028 Pro с STR 1.2.4.137
  • Crazyscan finds the "targets" on the UK spot at 28.2E, and IQmonitor 1030 locked them subliminally.
  • ... not on my Location
  • 11476 V,825,2/3,8PSK-GS
    It is a beautiful constellation with IQmonitor(on CS, too) on a mux with a low symbol rate of 21.6E. It's new. I haven't seen it reported.
    And, of course, a scan at this position with IQmonitor and Crazyscan
  • Bei mir , fast das gleiche Ergebnis .
    practically the same result on my side
  • hier, was wir derzeit auf der Position 9,4 West empfangen können, wo sich Astra 1P im Test ist.
    here what we can currently receive on the 9.4 West position, where Astra 1P is being tested.
  • Nach langer Zeit wollte ich mal wieder alle TV Applikationen für meine TBS 6922SE aktualisieren.
    Ich habe damals IQ Monitor benutzt.
    Doch nun schaffe ich es nicht, diese Software zum Laufen zu bekommen: das Programm started, doch friert komplett ein.
    Gibt es da was zu beachten?
    Ich benutze Windows 11 Professional 64 Bit.
    Mein Standort: 41° 13′ 00″ N, 8° 32′ 30″ O
    Meine Schüssel: No-Name Alu-Offset-Dish 120cm, mit DiSEqC-1.2 Motor.
  • Welche Version des IQMonitor?
  • Die TBS6922SE ist eine des Typs TMAX TAS210x, diesen Typ habe ich nicht. Daher kann ich das Verhalten des IQMonitors nicht erahnen.
    Sicher ist aber, dass deine Versionen noch aus dem Anfangsstadium der Pro-Versionen stammen. Die letzte light Version und auch die 2.4.0.7 laufen recht stabil.
  • Hier kann man die Version 2407 herunterladen
    strannik
    November 7, 2020 at 1:59 PM
