I noticed this satellite on FS list, so I checked it.
Hope it is correct.
All locked TP are GS.
Hope it is correct.
Looks like at least 2 different beams active here. I get all the V signals but not the H ones. The peaks on my scan of 11450-11700H are overspill from Hispasat.
/edit by qwer: Thanks for your report SatSearcher. Please use "Dateianhänge bearbeiten" button to upload your attached files.
/edit by qwer: LINKs disappeared (01.08.2020).
Some visible changes in V, on this position.
In H pol. only 11124 left.
Very strong 11516 V 1200 5/6 QPSK2 Multi .
Btw. inclination is 0,7 deg. not 0,3 .
11171 V,32000,3/4,dvb-S2/32APSK,ACM,Single-new GS
added:11096 H,28190,3/4,Dvb-S2/16APSK,ACM-new GS
from my place for this zombie-sat
I put some of them here :
look like summer beam spot2 still active .to day I can see:
10992,H,46995,56,16APSK SR changed
11060,H,35330,34,32APSK
11097,H,28187,34,16apsk still not locked ....?SR changed
11177,H,23330,34,32APSK
11495,H,44990,34,32APSK
11595,H,32720,34,32APSK
and there is also
11124,H,10350,23,16apsk still not locked but SR changed
and from Hispasat 30W-6
5=11491,V,7522,89,8PSK not locked
11573,V,20950,34,32APSK not locked
11124,H,10284,78,Qpsk still not locked but
SR in crazysan now is 10284 last time is 10350
SR in IQmonitor is 10486 with low validity 18%
summer beam spot 1 or fake TP ?
Better result now with IQmonitor
11124,H,10284 still not locked (-2.71dB) may be summer spot2
new I think
11163H8957 16Apsk 3/4
11182H16055 unknown & no locked !
Hi flie,
11182 H also not lockable from my place (2.2m).
My scan.
thank you very much Qwer
from my place I can see only Horizontal Tps from IS903 summer spot 2
we can guess that all vertical Tps are from IS903 summer spot 1
I cant see anything from this satellite now .
Beacon at 11452V visible.
Hi marval450,
same situation here too.
PS: Let´s wait a bit until I "refresh" GS list...
same situation here too NO THING from INTELSAT903
Apparently the "summer beam" is active only in the summer
the only thing with signal is 12283,V,2199 from IS 25 @31.5°W
others without signal and not from INTELSAT903:
11491,V,7522,8/9 No locked from 30W-6 @30°W
11890,H,3329,3/4 No locked from 30W-6 @30°W
4=12333,V,6427,7/8 No locked from IS 25 @31.5°W
5=12602,H,9998,8/9 No locked from 30W-6 @30°W
let us wait until next summer
I found only a transponder active on this incl. satellite:
11554 V,32726,3/4,32APSK,ACM,GS
Intel 903,update from my area
11075 H,45000,3/4,32APSK,ACM,GS,
11168 V,43617,8/9,16APSK,ACM,GS,
11507 H,45000,2/3,16APSK,ACM,GS,
11555 H,30000,5/6,16APSK,ACM,GS,
11635 H,32726,3/4,32APSK,ACM,GS,
It is back on. My scan.
is back here too
no thing in Vertical polarity as expected -I can't see IS903 summer spot 1!-
11555 H,30000,8/9,16APSK,ACM,GS-Vpid-256,Apid-257,
11587 H,18757,3/4,S2,ACM,Multi 1-new GS
