11.5°E Sicral 1B
    Needs confirmation that this is ComsatBw-2 - probably not, more likely SICRAL 1B <Edited 30/7/19)>
    2240.96MHz RHCP
    1.2m dish
    521ks/s, 524K FFT
    3 Mal editiert, zuletzt von s-band ()
  • I have this frequency for SICRAL 1B. on 11.5° E.
    _______________________________________
    L-Band 100 cm
    S-Band 370 cm, downconverter to 400 Mhz
    X-Band 180 cm, NORSAT LNB XT 1000 N
    Ku-Band 180 cm, Norsat Quad band LNB 1000 HU
    Ka-Band 180 cm, Norsat and Inverto LNB
    Receiver AR 5000 + NetSDR, SDRplay RSP2pro
    Original von Triker
    It is hard for me to tell with the 1.2m dish. It does not look like Comsat's X band TT&C so you are probably right, thanks.
    The earlier plot was without a GPSDO. The one below is with GPSDO so the frequency should be correct now.
    I left it running and noticed that the modulation changed for a while around 18:45GMT. See 2nd plot.
    /edit by qwer: Changed toppic name. Thank you!
