42.0°E Türksat 3A/4A
  • actuell, 11958 V 27500 had changed from westbeam to türkei beam, now 11958 H
    reception with 180 7,2dB in the morning, softly raining
    1 Gib. 150
    1 T90
    1 Gib. 125
  • I'm not sure if you have noticed new 11820 H 14166 S2 8PSK 3/4
    reception with 11,9dB, I think eastbeam
    1 Gib. 150
    1 T90
    1 Gib. 125
  • every day at afternoon signal of 11958 H will be weaker and beginning evening signal leave us.
    1 Gib. 150
    1 T90
    1 Gib. 125
    Kleinraisting,
    just my signal for 11822 H (11.2dB) and 11958 V (6.0dB) at 18.45pm.
  • a new situation: 11767 V 15000 8PSK 3/4 and 11795 H 30000 8PSK 3/4 all turkiye beam are new;
    signal from 11767 V is a little weaker (7,8dB because bad modulation) than 11977 H QPSK 5/6), signal of 11795 is weaker than 12015 (on my place 5,2dB).
    1 Gib. 150
    1 T90
    1 Gib. 125
  • just the moment:
    11767 V (TRT 4K) 8,1dB reception; 11795 H 5,5dB far away (8dB are needed).
    11958 7,7dB rec.
    11977 7,6dB rec.
    12015 6,7dB rec.
    12329 3,2dB no rec.
    1 Gib. 150
    1 T90
    1 Gib. 125
  • New Turkey b. TPs.
    I think 12083 H 13750 2/3 DVB-S2/8PSK is In Turkey too, it is weaker than east TPs(10,5db).
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Just my signal on 12083 H.
  • on my place just the moment and the hole day 9,9dB with Gib. 150 (F16).
    I'm sure 12083 H is an east beam-tp
    1 Gib. 150
    1 T90
    1 Gib. 125
  • Well, then the TP is in East b.:74:
    TBS 6983
  • 12604 V,34284,2/3,16APSK.HEVC-Turksat 8K ( ZAZA & VictorLS on FS)
    Just my poor signal scan in this range after a longer time. :37:
    11977 H from Turkey beam is possible today on my setup - East beam TPs okay so far... only 11853 H under lock.
    PS: Only constellation on 12015 H
    /edit: Forgot in vertical: 11958 V
    Just a first-of-august-scan in this range. Bad situation for Turkey beam now: only 11958 V lockable (TBS 6522).
  • Turksat 3A/4A signal in my area at this time :3:
