3803 R Fashion One 4K added
47.5°W SES-14
new freq and SR
3840 R 15000 2/3Go TV: 4165 L 3161 3/5
What is your opinion about 3978 L which has started some weeks ago ?
forget it, not NS3/4
What is your opinion about 3978 L which has started some weeks ago ?forget it, not NS3/4
SR is 33.8 but the shape is unusual .
It seems to be the so called "carrier inside carrier".
When forward and return channel are on the same slot.The higher part of the carrier at 3978 is sharp (as 5% roll off) but lower part looks like 15% roll off.
This is a possible carrier in carrier case. -
3803 R new SR 32720 (not an unknown SR for real DXers....)
more channels to come ?
I was right, it arrives
3803 R new SR 32720 (not an unknown SR for real DXers....)more channels to come ?
Just a todays look on this one - 3803 R.
/edit:
Probably new? /TierraMia HD on 3834 R 15000 2/3
3790 L 30msps
Asteroid day channel added -
Just to report this screenshot
El Garage TV is FTA 3834R
Just my scan after a long time - nothing new appeared.
(3889 from opposite polarisation)
4095 L 30000 2/3 CNN Brasil Promo added
4095L, CNN Brazil also available in SD, with a short delay (5 seconds)
PS 3985 R SR is now 16665
New parameter for this package and complete scan:
3892 L 15000 3/4 DVB-S2
Just an update: Listed as circular left on LyngSat @estewrok 11.08.2021 Mórbido TV (Mexico).
3740 R 2343 5/6 DVB-S2 8PSK
Changed frequency:
4031 R 2343 5/6 DVB-S2 8PSK
Not new, Satfaca on DXtv 08.10.2021:
3898 L 5000 3/4 DVB-S2 8PSK, Record Nacional
Für euch alle höchswahrscheinlich nicht besonderes ,
Es ist das erste Mal, dass ich diese satellite überhaupt empfangen kann.
Nur einen Transponder gelockt
4026 R 4998 DVBS2 8PSK 3/4
TIEMPO REAL HD
Probably nothing special for all of you,
It's the first time I've ever been able to receive this satellite.
Only one transponder locked
TIEMPO REAL HD
Hello
What is your location? If you live in Germany you should find more transponders.
In my case, in Sweden, there are three transponders on the 180cm antenna.
Hello
Ich habe es gerade noch einmal versucht.
Mit einer noch feineren Einstellung habe ich es geschafft, CNN Brazil zu empfangen.
Aber für 3834 R 15000 mit 5dB bin ich zu grenzwertig.
Gratulation
Mit meine KU Empfangen bin ich aber zufrieden .
Man muss auch sehen , dass bei mir am Horizont ein Dach kann schon ein bisschen stören
I just tried again. With an even finer adjustment,
I managed to receive CNN Brazil but for 3834 R 15000 with 5dB I'm too limited.
on the other hand in Ku band my result is decent .
You also have to see that with me on the horizon a roof can already disturb a bit
I noticed that you have some kind of mechanism that turns the Cbanda to Ku converters.
Can you send some pics of this invention to me on email?
greetings
greetings
Hier ein bild bei diesem Forum
Here is a picture at this forum
