TBS6909X DVB-S2X & ACM/VCM
  • new arrival from TBS company
    tbs6909x DVB-S2X/S2 & ACM/VCM
    I am confused about this "TBS6909xChangeModeTool" ..I guess to change between S2/S2X!
    I think before that silabs demods can not handle DVB-S2X & ACM at the same time ?!
    if that is true so tbs6909x it will not be able to ACM & DVB-S2X at the same time ! but separately
    so you have to change always the mode and compare between two result of blindscan
    any way I don' know ..we can wait until some one try it :73:
    crazycat said:"6909x is some new experimental device based on STiD135. Have full DVB-S2 ACM/VCM + MIS support + advanced S2X support . STiD135 very complex and flexible chip, many capabilities not covered by current drivers/software."
    I hope if there is a USB version in future .
    https://www.tbsdtv.com/product…octa-tuner-pcie-card.html
    [Blocked Image: https://www.tbsdtv.com/product…s/tbs6909x/tbs6909x_1.jpg]
    Main Features:
    Support Octa DVB-S/S2/S2X
    Fast scanning functionality for all media
    Support VCM, ACM, CCM, QPSK, 8PSK, 16APSK, 32APSK;
    Support wide band
    DVB-S/S2/S2X
    DVB-S/S2 QPSK 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
    8PSK 3/5, 2/3, 3/4, 5/6, 8/9, 9/10
    16APSK 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
    32APSK 3/4, 4/5, 5/6, 8/9, 9/10
    DVB-S2X QPSK 1/4,1/3, 2/5 (S2-MODCODs)
    8/9, 9/10 (S2-MODCODs)
    11/45, 4/15, 14/45, 7/15 8/15, 32/45
    8PSK 3/5, 2/3, 3/4, 5/6, 8/9 (S2-MODCODs)
    7/15, 8/15, 26/45, 32/45
    16APSK 2/3, 3/4, 4/5, 5/6, 8/9 (S2-MODCODs)
    7/15, 8/15, 26/45, 3/5, 32/45
    32APSK 2/3, 32/45
    VCM Yes
    ACM Yes
    Power consumption
    Input/ Power: 12V/7~15W
    temperature 0°~ 60°
    Other information:
    System Requirements Windows XP / Vista/ 7/8/10, Linux
    Available PCI Express x1, x4, x8 or x16 slot
    Dimension:
    TV tuner card size 145*92*1.6mm
    Gift Box Size 200*130*30mm
    Weight 400g
    Package Contents 1* TBS6909-X
    1* Power cable
    Edited once, last by flie ().
  • For the moment 6909X is like a rich mine that can't be exploited because they are not the right tools to exploit it :88: Salvation comes from CrazyCat's brilliant mind(My hat off)
  • according to crazycat :
    TBS6909xChangeModeTool is :
    LNB connection mode. Similar to linux drivers for mxl584 (TBS 6909). Multiswith or direct connection mode.
    I thought the tool like : tbs5521_changemode_tool
    may be whe can understand how TBS6909xChangeModeTool works if we look also to Lnb max-sx8 connection mode
    [Blocked Image: https://pictures.digitaldevices.de/repository/produkte/820148/Max_sx8-produktbeschreibung-08052018-DE.png]
  • ... but the SR on TBS6904-X is up to 45000, on the 6909 it is not specified.
    I think, I still wait for a professionell X-version.
    Original von femi
    you are right but TBS6904-X doen't support ACM :
    https://www.tbsdtv.com/product…quad-tuner-pcie-card.html
    Main Features:
    Support Quad DVB-S/S2/S2X
    Support VCM, CCM, QPSK, 8PSK, 16APSK, 32APSK;
    Up to 173M/bps(TS Data Rate)
    Quad flexible TS interfaces
    Model TBS6904-X
    symbol rates 1-45Msps
    DVB-S/S2/S2X
    DVB-S2X QPSK 13/45, 9/20, 11/20
    2_4_2_APSK 100/180, 104/180
    8PSK 23/36, 25/36, 13/18
    8_8_APSK 90/180, 96/180, 100/180, 18/30, 20/30
    16APSK 26/45, 3/5, 28/45, 23/36, 25/36, 13/18, 140/180, 154/180
    4_12_16rb_APSK 2/3
    4_8_4_16_APSK 128/180, 132/180, 140/180
    Power consumption
    temperature 0°~ 60°
    Other information:
    Digital TV signal (ISDB-T/DVB-T2/C2/S2X/S2/T/C/S)
    Dimension:
    Net weight 189g
    Weight 400g
    Package Contents 1* TBS6904-X
    1* Power cable
  • thank you again Crazycat :71: :"TBS 6909x support 256ASPK, same chip STiD135. :94:
    P.S. But anyway this not tested I receive some DVB-S2X, QPSK from 19.2E some time ago"
    let us wait until some one test TBS 6909x :83:
  • TBS IPTool v.3.0.5.3 and TBS TSRecorder v.3.0.1.6 have been updated for TBS6909-X
  • Edited once, last by flie ().
  • Thank you, flie,but I have to admit it's not my merit.There's still work on this card.It's not really that easy for programmers to solve such a complex card.
    I do not know that such a 256APSK mode has been used.Until it goes to this mode,as the song says,it's a long, long way to...Tipperary
  • Update driver for tbs6909-X_v.1.0.0.3
  • Hello,
    I would like to ask and get a little more information about this card model: TBS-6909-X V2
    Is there Generic stream mode Support? And does it manage to capture continuously BB Frames.
    Best Regards!
  • CrazyCat recommended Dektec DTA-2137C for BBFrame some long time ago, now DTA 2132 it is probably suitable for DVB-S2X
    DigitalDevice recommends for BBFrame MAX SX8
    Rick also had an interesting discussion about the use of BBFrame in TBS cards
  • Thanks a lot for the information and help.
    I'm about to buy PCIe card and I hesitate between TBS-6903-X and 6909-X V2, because both have the same chip STiD135.
    So I want to get some information by someone who has tested 6909-X V2 to capture BBFrames.
    I think I will choose TBS-6903-X as there is a bit more information about her Generic stream support.
    Best Regards!
  • The Digital Devices Max SX8 Pro also has the STID135 chip and I fear the same problems with the software.
    The company is not sure whether it works with Crazyscan, for example, and obviously nothing was known about the IQMonitor.
