Some signals have emerged horizontal polarization.Maybe some new satellite on the way.Can someone check?
57.0°E NSS-12 <ME/Europe>
Thank you milan58!
Checkded with TBS 6522 - probably data, empty now...
12553 H 3502 13/18 DVB-S2X 16APSK
12557 H 3502 13/18 DVB-S2X 16APSK
Nice catch
12552 H(9,4dB) and 12556 H(8.9dB),3502,13/18,S2X-locked with tbs6590 card
12552 H(9,4dB) and 12556 H(8.9dB),3502,13/18,S2X-locked with tbs6590 cardStronger signal at 12552 H which attenuates much on the 12555 H,for this reason it does not lock.
12552 H,3501,23/36,8PSK,ACM-Data,new fec & mode,
(12555 H,3501,23/36,8PSK,ACM-Data,new fec & mode.)Now both transponders also in DVB-S2 with tbs6983:
It seems that S2X was dropped for 12552 H and 12556 H,now only in Dvb-S2.
Tested with tbs6590 and tbs6903X. -
It's my first time for me:
12551,H,3500,34,8PSK
12555,H,3500,34,8PSK -
Now only in S2X and the same FEC:25/36
This morning FEC was changed to 13/18,now it is at 1/4 and no s2x ext.
Again 12552 H s2x ext and fec 25/36
Again 12552 H s2x ext and fec 25/36Now FEC changed:13/18
12555 H,3501,13/18,16APSK/S2X -
Again 12552 H s2x ext and fec 25/3612552 H,3500,3/4,8PSK-now without S2X extension(with tbs6983 & tbs6590).
12555 H,3501,13/18,16APSK/S2XAt this time,12551 H with the s2x extension again:8PSK,fec 23/36
12555 H has remained with the same parameters:16APSK/S2x,fec 13/18. -
I have the impression that most transponders in the upper band are in S2x,but at the same time modulation is constantly changing.Certainly a strong signal is needed for the tuner to read the parameters correctly.With the fluctuating signal coming from M.East beam you can not be sure if all the parameters are correct.
I'll mention to this section all transponders that I get from 57.0 E because RollOff is used for the S2X extension:12521 H,1057,23/36,RollOff-0.35,ACM-Data,
12532 H,6070,4/5,RollOff-0.05,ACM-Data,
12551 H,3501,3/4,8PSK,RooOff-?,ACM-Data,
12555 H,3502,13/18,16APSK,RollOff-0.05,ACM-Data,
12575 H,5836,5/6,5/6,RollOff-0.05,ACM-Packetized,
12642 H,1000,2/3,8PSK,RollOff-0.35,ACM-Data,
12652 H,6070,5/9,S2X-8PSK,RollOff-0.05,ACM-Data,
12659 H,3959,1/4,S2,ACM-Data,12543 H,3961,23/36,S2X/16APSK,ACM-Data,
12630 H,5209,3/4,32APSK-?Because I also used other cards,the results are different.That's why I edited the spectrum with the last two transpondes from which I have no constellation.
12646 H,6071,5/9,S2X/8PSK_L,RollOff-0.05,ACM-Data
12513 H,5274,23/36,8PSK,RollOff:0.05,ACM,stream Packetized,
12518 H,4662,13/18,8PSK,RollOff:0.05,ACM-Data,
12522 H,1057,23/36,8PSK,RollOff:0.35,ACM-Data,
12551 H,3501,13/18,16APSK,RollOff:0.05,ACM-stream Packetized,
12562 H,932,13/18,8PSK,RollOff:0.05,ACM-Data. -
12568 H,9186,11/20,Dvb-S2,RollOff:0.05,ACM-Data
...12521 H,1057,23,36,(SDX)/8PSK,RollOff:0.35,ACM-Data
Just my results - nothing new, according satesco´s reports, even when I have +2MHz more...
12514 H 5274
12519 H 4663
12557 H 3500
12648 H 6070
12654 H 6070
12581 H,3791,25/36,8PSK,0.05-Packetized(not new)
