ZitatOriginal von qwer
Just a try with the chinese extended Ku (thanks to moonbase, click for satellites.co.uk forum) on this range, using CrazyScan Version 1.02.149 and TBS 6903.
That's a big image response
Was that with the WR75 LNB or the 40mm LNB?
Nothing shown here qwer at those frequencies you show. 1.2 Gibertini , 12.75-13.75 metal cased lnbf
Hi,
it was with the WR75 LNB.
Not tested the 40mm (plastic) LNB yet.
Hallo
Diesmal mit einem modifizierten LNB ; 25MHz Quarz gegen einen 24MHz ausgetauscht
This time with a modified LNB; 25MHz crystal exchanged for a 24MHz
ATM I found 8trps active at the same time,probably all allocated for subband(?).
10492 H,1500,4/5,S2-A71A,
10493 H,1000,5/6,S2-1 IZ1VWE,
10494 H,1000,2/3-?
10495 H,333,2/3,S2-DL3HQD,
10496 H,333,4/5,S2-IKHYU,
10497 H,333,3/4,S2-F6GDL,
10498 H,333,3/5,S2-f5nvp,
10499 H,333,1/2,S2-ON5AFB.
added also:10495 H,500,5/6,S2-IZ1 HXI.
Again many transponders active at the same time atm
Very impressive, s-band, finding SR 71.
I think it was probably SR = 66 but it did not stay up for long enough to lock. I have no doubt it would have locked but it needs a fair bit of tweaking and a few re-scans to get the lower SRs. That is one problem with the software, the first guess is usually a bit off.
Tests with a Chinese lnb for 10.0-107GHz with the tbs6983,tbs6903X cards and DM920UHD.
Besides the fact that it's being worked carelessly,the lnb still needs to be calibrated.To bring it the desired frequency,I had to set the local oscillator at 8992 MHz and not at 9000 MHz,as recommended by the BWEI manufacturer.If I set it at 9GHz then the frequencies would pass 10500 MHz.
Just another look on these ones - after 1,75 years, using 2.2m and Inverto single flange on CrazyScan Version 1.0.2.146.
/edit: next catches/during the day...
10492.7 H 500 3/4 DVB-S2 QPSK - DD0CW
10493.2 H 1000 3/4 DVB-S2 QPSK - DD4YR
10494.5 H 1000 2/3 DVB-S2 QPSK - DD0CW
10494.7 H 500 2/3 DVB-S2 QPSK - Digital TV
10494.7 H 1000 3/4 DVB-S2 QPSK - DM2CFL - Hartmut
10494.7 H 1000 4/5 DVB-S2 QPSK - DD4YR
10495.7 H 333 3/4 DVB-S2 QPSK - DG1GCW (too fast for dB and screenshot)
10495.7 H 500 3/5 DVB-S2 QPSK - R0AU
10495.7 H 500 3/4 DVB-S2 QPSK - DG1GCW
10496.2 H 500 4/5 DVB-S2 QPSK - IU4GAV (6.8dB earlier)
10496.2 H 1000 2/3 DVB-S2 QPSK - PA0ASW
10496.2 H 1000 4/5 DVB-S2 QPSK - IU4GAV
10496.7 H 333 2/3 DVB-S2 QPSK - AMP TEMP TEST
10496.7 H 500 2/5 DVB-S2 QPSK - SV9IQ TEST MODE
10496.7 H 500 1/2 DVB-S2 QPSK - AMP TEMP TEST
10496.7 H 500 1/2 DVB-S2 QPSK - SV9IQ TEST MODE
10497.2 H 333 2/3 DVB-S2 QPSK - G8KOE
10497.2 H 333 2/3 DVB-S2 QPSK - IU4GAV
10497.2 H 333 2/3 DVB-S2 QPSK - DL1LQ_Joern
10497.2 H 333 3/4 DVB-S2 QPSK - dj0qo
10497.2 H 333 3/4 DVB-S2 QPSK - IZ3JYJ
10497.2 H 333 4/5 DVB-S2 QPSK - DK7UC
10497.2 H 333 4/5 DVB-S2 QPSK - IU4GAV (10.0dB earlier, too late for screenshot)
10497.7 H 333 3/4 DVB-S2 QPSK - IK6BLO
10497.7 H 333 3/4 DVB-S2 QPSK - IK2OWU
10498.7 H 333 2/3 DVB-S2 QPSK - DL1LQ_Joern
10498.7 H 333 2/3 DVB-S2 QPSK - OE6THD
10499.2 H 250 3/5 DVB-S2 QPSK - F6DES
10499.2 H 333 2/3 DVB-S2 QPSK - F6DES
10499.2 H 333 3/4 DVB-S2 QPSK - PA2JSA
