QuoteOriginal von qwer
Just a try with the chinese extended Ku (thanks to moonbase, click for satellites.co.uk forum) on this range, using CrazyScan Version 1.02.149 and TBS 6903.
That's a big image response
Was that with the WR75 LNB or the 40mm LNB?
Nothing shown here qwer at those frequencies you show. 1.2 Gibertini , 12.75-13.75 metal cased lnbf
QuoteOriginal von moonbase
Hi,
it was with the WR75 LNB.
Not tested the 40mm (plastic) LNB yet.
Hallo
Diesmal mit einem modifizierten LNB ; 25MHz Quarz gegen einen 24MHz ausgetauscht
This time with a modified LNB; 25MHz crystal exchanged for a 24MHz
ATM I found 8trps active at the same time,probably all allocated for subband(?).
10492 H,1500,4/5,S2-A71A,
10493 H,1000,5/6,S2-1 IZ1VWE,
10494 H,1000,2/3-?
10495 H,333,2/3,S2-DL3HQD,
10496 H,333,4/5,S2-IKHYU,
10497 H,333,3/4,S2-F6GDL,
10498 H,333,3/5,S2-f5nvp,
10499 H,333,1/2,S2-ON5AFB.
added also:10495 H,500,5/6,S2-IZ1 HXI.
Again many transponders active at the same time atm
Very impressive, s-band, finding SR 71.
I think it was probably SR = 66 but it did not stay up for long enough to lock. I have no doubt it would have locked but it needs a fair bit of tweaking and a few re-scans to get the lower SRs. That is one problem with the software, the first guess is usually a bit off.
