25.8°E Es'hail 2 DATV 10.5 GHz
    Just a try with the chinese extended Ku (thanks to moonbase, click for satellites.co.uk forum) on this range, using CrazyScan Version 1.02.149 and TBS 6903.
    That's a big image response :43:
    Nothing shown here qwer at those frequencies you show. 1.2 Gibertini , 12.75-13.75 metal cased lnbf
    Original von moonbase
    Was that with the WR75 LNB or the 40mm LNB?
    Hi,
    it was with the WR75 LNB.
    Not tested the 40mm (plastic) LNB yet.
    :72:
    Hallo
    Diesmal mit einem modifizierten LNB ; 25MHz Quarz gegen einen 24MHz ausgetauscht
    This time with a modified LNB; 25MHz crystal exchanged for a 24MHz
  • ATM I found 8trps active at the same time,probably all allocated for subband(?).
    10492 H,1500,4/5,S2-A71A,
    10493 H,1000,5/6,S2-1 IZ1VWE,
    10494 H,1000,2/3-?
    10495 H,333,2/3,S2-DL3HQD,
    10496 H,333,4/5,S2-IKHYU,
    10497 H,333,3/4,S2-F6GDL,
    10498 H,333,3/5,S2-f5nvp,
    10499 H,333,1/2,S2-ON5AFB.
    added also:10495 H,500,5/6,S2-IZ1 HXI.
  • Again many transponders active at the same time atm
    satesco It's hard to get so many at once, nice captures. Here's a full band scan using the Minitiouner
    Very impressive, s-band, finding SR 71. :35:
    I think it was probably SR = 66 but it did not stay up for long enough to lock. I have no doubt it would have locked but it needs a fair bit of tweaking and a few re-scans to get the lower SRs. That is one problem with the software, the first guess is usually a bit off.
  • Tests with a Chinese lnb for 10.0-107GHz with the tbs6983,tbs6903X cards and DM920UHD.
    Besides the fact that it's being worked carelessly,the lnb still needs to be calibrated.To bring it the desired frequency,I had to set the local oscillator at 8992 MHz and not at 9000 MHz,as recommended by the BWEI manufacturer.If I set it at 9GHz then the frequencies would pass 10500 MHz.
  • SMW WDL TYPE E lnb.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
    Zwei Funkamateure unterhalten sich
    jeder mit seiner eigenen Frequenz
    Two radio amateurs are talking
    each with its own frequency
    as often on Sundays, there is a lot of action today among amateur radio stations.
    Wie oft am Sonntag , gibt es z.Z. ziemlich viel Actions bei den funkamateur.
    Heute ein Funkamateur aus Deutschland ( Hartmut - DM2CFL) , und mit sr 1000
    Today a radio amateur from Germany ( Hartmut - DM2CFL) , and with sr 1000
    Nicht einfach , ein Bild mit sr 250 zu bekommen , heute ist es mir gelungen
    Not easy to get a picture with sr 250 , today i succeeded
    Нелегко сделать снимок с sr 250, но сегодня мне это удалось.
    DL9DAC
    10497,2 H 250 4/5 DVB-S2 QPSK2
    Just another look on these ones - after 1,75 years, using 2.2m and Inverto single flange on CrazyScan Version 1.0.2.146.
    /edit: next catches/during the day...
    10492.7 H 500 3/4 DVB-S2 QPSK - DD0CW
    10493.2 H 1000 3/4 DVB-S2 QPSK - DD4YR
    10494.5 H 1000 2/3 DVB-S2 QPSK - DD0CW
    10494.7 H 500 2/3 DVB-S2 QPSK - Digital TV
    10494.7 H 1000 3/4 DVB-S2 QPSK - DM2CFL - Hartmut
    10494.7 H 1000 4/5 DVB-S2 QPSK - DD4YR
    10495.7 H 333 3/4 DVB-S2 QPSK - DG1GCW (too fast for dB and screenshot)
    10495.7 H 500 3/5 DVB-S2 QPSK - R0AU
    10495.7 H 500 3/4 DVB-S2 QPSK - DG1GCW
    10496.2 H 500 4/5 DVB-S2 QPSK - IU4GAV (6.8dB earlier)
    10496.2 H 1000 2/3 DVB-S2 QPSK - PA0ASW
    10496.2 H 1000 4/5 DVB-S2 QPSK - IU4GAV
    10496.7 H 333 2/3 DVB-S2 QPSK - AMP TEMP TEST
    10496.7 H 500 2/5 DVB-S2 QPSK - SV9IQ TEST MODE
    10496.7 H 500 1/2 DVB-S2 QPSK - AMP TEMP TEST
    10496.7 H 500 1/2 DVB-S2 QPSK - SV9IQ TEST MODE
    10497.2 H 333 2/3 DVB-S2 QPSK - G8KOE
    10497.2 H 333 2/3 DVB-S2 QPSK - IU4GAV
    10497.2 H 333 2/3 DVB-S2 QPSK - DL1LQ_Joern
    10497.2 H 333 3/4 DVB-S2 QPSK - dj0qo
    10497.2 H 333 3/4 DVB-S2 QPSK - IZ3JYJ
    10497.2 H 333 4/5 DVB-S2 QPSK - DK7UC
    10497.2 H 333 4/5 DVB-S2 QPSK - IU4GAV (10.0dB earlier, too late for screenshot)
    10497.7 H 333 3/4 DVB-S2 QPSK - IK6BLO
    10497.7 H 333 3/4 DVB-S2 QPSK - IK2OWU
    10498.7 H 333 2/3 DVB-S2 QPSK - DL1LQ_Joern
    10498.7 H 333 2/3 DVB-S2 QPSK - OE6THD
    10499.2 H 250 3/5 DVB-S2 QPSK - F6DES
    10499.2 H 333 2/3 DVB-S2 QPSK - F6DES
    10499.2 H 333 3/4 DVB-S2 QPSK - PA2JSA
  • 10498.7 H 333 2/3 DVB-S2 QPSK - DL1LQ_Joern
    10498.2 at my setup today... :26.
  • Today there were enough transmissions with SR-66 , I haven't seen the SR-33 yet
