• Highest here is 10890 H with 3,3db. Still far away. :28:
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Edited once, last by marval450 (March 29, 2020 at 6:58 PM).
  • my scan at this position :72:
    some TPs are left :88:
    A bit more atm.:89:
    TBS 6983
  • Just my look on this position - I´m "negative" here... :26.
    (maximal "-10dB" in manual and on some in horizontal...)
  • "Noon" scan... in range 10.70 to 10.95 GHz:
    10730 V 27500 2/3 DVB-S2 8PSK (6.0dB under LM) -> best signal (according scan) from my place :90:
    10730 H 30000 3/4 DVB-S - no signal
    10770 V 27500 3/4 DVB-S2 8PSK (6.6dB under LM)
    10770 H 27500 3/4 DVB-S2 8PSK (9.1dB under LM)
    10810 V 27500 2/3 DVB-S2 8PSK - did not appeared in BS (-0,1dB; 6.7dB under LM)
    10810 H 27500 2/3 DVB-S2 8PSK (6.0dB under LM) -> best signal (according scan) from my place :90:
    10850 H 27500 2/3 DVB-S2 8PSK - did not appeared in BS (-0,3dB; 6.9dB under LM)
    10890 V 27500 2/3 DVB-S2 8PSK (6.4dB under LM)
    10890 H 27500 2/3 DVB-S2 8PSK (8.8dB under LM)
    10930 V 27500 2/3 DVB-S2 8PSK (6.4dB under LM)
    ...but getting nearly all vertical ones "in positive" now... :26.
  • ...and in range 11.3 to 11.45 GHz - only manual scan - nothing possible in "no-locked" BS:
    11310 V 27500 2/3 DVB-S2 8PSK (8.9dB under LM)
    11310 H 27500 2/3 DVB-S2 8PSK - not sure about this signal? (signal is "jumping")
    11350 V 27500 2/3 DVB-S2 8PSK (9.4dB under LM)
    11350 H 27500 3/4 DVB-S - no signal
    11390 H 27500 2/3 DVB-S2 8PSK (9.3dB under LM)
    11430 V 27500 2/3 DVB-S2 8PSK (9.4dB under LM)
  • Just my try in 2022 in lower range - using 2.2m...
    Probably there is something at 10890 V 27500 again? :90:
  • Eshail1 no any signs of signal here.
    Eshail 2 is most powerful satellite from 26east here. That's actually scan from him.
  • Here's my checking for this position with feed not calibrated.
    Only 10730 H lockable at -10dB, but not realized in Constellation Monitor.
    Other Freqs. are far from lock
    RotorFeed: C LR/HV+KU H/V
    TBS5925-6983+6908
    RC2000C
  • My trying in half november, evening time.
    A little better than last time... :128:
    TBS5925-6983+6908
    RC2000C
  • Just my very poor "far away from lock" scan in year 2024 on 2.2m from my place...
  • Just my contribution, via this position (1.8m cloudy)
    6522:
  • Just my current scans... far away from lock... best signal 10810 V =about 4.5dB under link margin... no signals above 11.3GHz...
  • My scans using a 1.8m PF with a modified Bullseye LNB from 40k E of London, UK. Note that the skew was set for Eutelsat so not optimum.
