TSReader tool
Just my try on 58.0°W.
PS: Started a new toppic "TSReader tool".
..the newest
QuoteDisplay MoreVersion 2.8, build 55:
Lite: Fixed a bug where pressing F5 didn't refresh the thumbnail view
Pro: Added DVB/SCTE-27 subtitle streams to the video/audio timing function since these also contain PTS
All: Added support for DVB Modulator Interface (T2-MI) streams. These are transport streams that contain full DVB-T2 transmission frames and are used to provide streams and timing information to DVB-T2 transmitters. When this mode is enabled, TSReader shows the resulting transport stream as if it were looking at the modulated output
Std/Pro: Added support for IPV6 UDP and RTP to the IPTV source module
All: The Dektec QAM sources now support the DTU-238
All: Fixed an issue with ATSC channel names containing special characters
All: Added decoding of ISO extended descriptors
Std/Pro: Added decoding for H.265 chroma encoding format
All: The H.264 thumbnail decoder no longer stops on an I-slice that isn't a scene change I-slice
All: Added support for the following TBS cards: 6504 (quad multi-tuner), 6522 (dual multi-tuner), 6528 (multi-tuner CI), 6590 (dual multi-tuner CI), 6903x (dual DVB-S/S2/S2X), 6904x (quad DVB-S/S2/S2X) and 6909x (octa DVB-S/S2/S2X)
All: Updated the internal TSID table used for ATSC stations. Now includes the latest repack RF channels, Canadian and Mexican stations. Many thanks to the guys at RabbitEars for the data
All: Moved a number of stream parser options from the Settings menu onto their own dialog as that menu was becoming too long
Pro: Added column descriptions to the Log CC/TEI report and added milliseconds to the time written to the log
Lite: The option to reset MPEG statistics (also triggered by the F6 key) now works
Pro: Fixed an issue with the TSWatcher status pages and system-wide HTML page not showing thumbnails from single channel streams
Pro: Added the ability to show thumbnails for single channel streams on top of the main TSWatcher window
All: Added decoding of the H.264 profile
All: Removed code and playback options for the now obsolete Stradis hardware decoders
All: Updated the Playback menu with support for VLC, PotPlayer and FFplay. Documentation on playback with these three players is here
I've often been asked how to get an IP-Over-Sat stream with TSReader,so I thought I'd post two videos,1.how to see the Live stream,and 2.to record the pid.
Tests at 27.5W on 11609 V,5723,8/9,16PSK,provider:RimminRadio.
TSReader Version 2.8, build 56
You can read the changes made in this release on the link given above
Nachdem die Seite https://www.tsreader.com nicht mehr existiert, ist zu befürchten, dass die Version 2.8.57 wohl die letzte war.
Since the site https://www.tsreader.com no longer exists, it is to be feared that version 2.8.57 was probably the last one. -
oh, que Dios lo tenga en su santa gloria,
que pena grande.
