10960 H,12666,2/3,Dvb-S2X/16APSK,Roll Off-0.20-Data,
11155 H,68572,13/18,Dvb-S2X/16APSK,ACM,Multi 1,Roll Off-0.05-Data,
31.5°W Intelsat 903 (incl.) END-OF-LIFE S2X>Ku
I think that 10960H is an s2 data
Original von Kypros_Pambou
I think that 10960H is an s2 dataI hope I'm not mistaken,but I believe they are transmitted in both standards.And it wouldn't be a novelty,if we remember that in the same way we found such transmissions at 43.2 W and at 57.0 E.
In this case we have to keep in mind that we have here a multi(s) 63 in mode S2.We also have to keep in mind that the signal is at the limit,on a incl satellite,and Crazyscan tries to capture and process this signal that is problematic to lock it.That's why we have a BER high on both modulations.Which makes Crazyscan to find other parameters every time.And up to a point,it's normal when we have a generic or encapsulated stream.
A similar situation is at 11471,23573,fec 13/18,roll off 0.05 on both mode,multi 1 & 63,where we have several parameters of S2X and streams with different stand.
I don't necessarily want to be right,but we have to admit that we still don't have the practice of interpreting such transmissions.For the time being we have to be content with the devices and applications that we have at our disposal,which,in some situations,do not help us very much -
This reception was with TBS 5927 that is not able to receive S2X signals -
...10962 H,16062,2/3,S2X/16APSK,RollOff:0.05,ACM,Multi 1-new symbol rate,
11048 V,17621,2/3,S2X/32APSK,ACM,Multi 1-DataFor those interested,I recommend to use pc cards that have S2X extension.It has already switched to the simultaneous transmission of the streams in dvbs2 and S2X on the same transponder.Even if the signal is strong, it can not be locked in many cases with demod dvb-s2.Just like the other positions I've tested.
11155 H,68572,13/18,Dvb-S2X/16APSK,ACM,Multi 1,Roll Off-0.05-Data,11155 H,fec 7/9,16APSK-added Multi:142 and 160
11587 H,18757,11/15,S2X/64APSK,CCM-new
11587 H_Dvb-S2,32APSK,79,34,0.10,ACM,Multi 1 and 63-Packetized -
Only one lock for me with TBS 6522:
10957 H 5476
[SIZE=1]Also in DVB-S2 mode.[/SIZE]
10956 H-MIS 63 and Roll Off:0.15
Intelsat 903 arrived at 31.5°W in October 2017, when it also started to become inclined.
A few days ago, started drifting West at graveyard altitude.
For now assuming the satellite is end-of-life, although it should be 2030 according Intelsat Form 10-K. That will be either a typo, or a later revival planned with a MEV.Intelsat 25 (launched 2008) is still at 31.5°W without inclination.
