16.0°E Eutelsat 16A
My todays scan on 1.8m with MCL-KP04.
Well, the guys in Cameroon fixed their antenna or finally fired up their amplifier, the Canal 2 package on 21576 H is back again with old strenght. Not tested with TBS 5927, but should be around 11,5 dB.
And the same for Benin and "Eden TV" on 21542 H, much stronger than the past months.
Here is my TBS 5927 scan with KaKU LNB - in light snowfall and a little bit of snow in the antenna.
Eden around 12 dB, Canal 2 around 11 dB, but still no sign of Golfe TV.
Substantial snow fall here at the moment in Central UK - Ka signals just about dissapeared - picture taken from 1.2 Gibby dish cam
qwer strannik Thick cloud here and a wet bag over the feed but here are some results from a beta release of Scan&Tioune using a Minitioner V2.0. It manages to blind scan and separate all signals including 21564. 21576 was just below lock and did not lock on the TBS6983 either. This set-up is great for identifying multiple, closely spaced, low SR, signals. It's a bit flakey but it is an early beta. You have to watch the SR display as it scans as it sometimes hangs on to a wrong value after displaying the correct one. It also gets the station names mixed up sometimes.
