16.0°E Eutelsat 16A
    Today's scan on a 1.2m near London
    Golfe TV, 21547 was off and Eden TV, 21541 was not picked up on the scan but is visible in the spectrum.
    My todays scan on 1.8m with MCL-KP04. :86:
  • Well, the guys in Cameroon fixed their antenna or finally fired up their amplifier, the Canal 2 package on 21576 H is back again with old strenght. Not tested with TBS 5927, but should be around 11,5 dB.
    And the same for Benin and "Eden TV" on 21542 H, much stronger than the past months.
    Thanks Afreaka !
    "Eden TV" (here; 21541 H) is okay now, but Canal 2 package still too low at my setup (21576 H) - had to try KaKu LNB next time...
  • Here is my TBS 5927 scan with KaKU LNB - in light snowfall and a little bit of snow in the antenna.
    Eden around 12 dB, Canal 2 around 11 dB, but still no sign of Golfe TV.
    Substantial snow fall here at the moment in Central UK - Ka signals just about dissapeared - picture taken from 1.2 Gibby dish cam:51::88:
    Thank you Afreaka and jaes for your great scan and nice dish cam photo! :31:
    Tried again right now (with same setup - MCL-KP04 LNB for band D and 1,8m): Signal increases on 21576 at this time.
    ... 21607 H - locked on the limit (manual scan)... :171:
    qwer  strannik Thick cloud here and a wet bag over the feed but here are some results from a beta release of Scan&Tioune using a Minitioner V2.0. It manages to blind scan and separate all signals including 21564. 21576 was just below lock and did not lock on the TBS6983 either. This set-up is great for identifying multiple, closely spaced, low SR, signals. It's a bit flakey but it is an early beta. You have to watch the SR display as it scans as it sometimes hangs on to a wrong value after displaying the correct one. It also gets the station names mixed up sometimes.
    Thanks s-band for showing us this nice tool!
    ...no problem at this time on 21607 H. :69:
    Again in linear here - very bad situation on 21576 H and only a manual lock on the limit on 21607 H.
    No signal on 21543 H 1100 (TVC) and 21547 H 1238 (Golfe TV).
    Hey, getting video content this weekend on 21607 H. :83:
    New, big mux: 21624 H 20666 3/4 DVB-S2 8PSK - 3 services in clear - others encrypted.
    Just another signal check at 10 a.m.:
    21607 H - lockable at this time
    21624 H - signal increased +0.3dB (according yesterday scan)
    21576 H - 2,1dB under LM on my setup (1.8m PFA and MCL-KP04)
  • TNT Sat Africa changed Frequenz ...
    now 21612 H 27580 3/4 DVB-S2 8PSK
    qwer:
    Diesmal habe ich den anderen F-Stecker gezogen :10:
    Hallo ,
    Kann jemand prüfen ob der 21538H 1055 noch existiert .
    Bei mir gibt es kein Signal ( trotz neue Antenne)
  • Nur 21591 war etwas zickig.
    ist es einen Blindcan von 16 Ost KA von Heute ?
    wäre besser das JPGBild die bei "save" in Spectrum geschpeichert ist ,
    hier als Anhang zu bringen ,drüber sind alle Parameter eingegeben.
  • 06.08.2021 16:02:57
    Es ist weniger aufwendig, aber mit den Programmdaten ein Hinweis für nicht geübte IQMonitor-User welche Einstellungen benutzt wurden, abgesehen von der höheren Auflösung.
    Beim Scan vor wenigen Minuten waren alle Signale wohl wetterbedingt schwächer, dass diesmal auch der 21564 H 130 3/4 manueller Nachhilfe bedurfte.
    Heute , nach ein kleine bisschen Feinjustierung konnte ich ein paar zehntel von dB gewinnen.
    und 21538 ist dabei
    Today, after a little tweaking, I was able to gain a few tenths of a dB.
    and 21538 is there
    Es ist erstaunlich, wie sich der Empfang vom KA-Band je nach Tageszeit sich verändern kann.
    Gestern um 17:00 bei gutem Wetter und 22° sehr gute dB Zahl.
    Heute Morgen um 7.30 Uhr auch bei schönem Wetter und 8° sind einige Transponder
    wirkich an der Grenze des Empfangs.
    It is impressive how the reception of the KA band can change depending on the time of day.
    Yesterday around 17:00 in good weather and 22° very good values.
    This morning at 7.30 am in good weather and 8° some transponders are at the limit of reception.
