16.0°E Eutelsat 16A
  • Nachdem 2 Peaks (21555 und 21556) mit dem IQMonitor zu sehen war, habe ich sie mir näher angesehen.
    Es dürfte sich nicht um unterschiedliche Transponder handeln.
    Dafür ist auch 21581 H 5570 3/4 8PSK aktiv. Auch hier fehlen ~3dB zum lock.
    After seeing 2 peaks (21555 and 21556) with the IQMonitor, I took a closer look at them.
    It should not be about different transponders.
    21581 H 5570 3/4 8PSK is also active for this. Here, too, ~3dB are missing for the lock.
    Увидев 2 пика (21555 и 21556) с помощью IQMonitor, я присмотрелся к ним поближе.
    Не должно быть про разные транспондеры.
    21581 H 5570 3/4 8PSK также активен для этого. Здесь тоже не хватает ~3дБ для блокировки.
    ...coming more near - yesterday evening- but still 1.4dB under lock on 21555 H 1183 3/5 (1,8m).
    I can´t verify "21581 H 5570"...
    C-band: 55.5°West-68.5°East ORBITRON O-16 (4,9m) / X-band: 17.8°W-60.2°E KATHREIN CAS 120 (1,2m) / Ku-band: 61.0°West-80.0°East KATHREIN CAS 23 (2,2m)
    Ka-band A/B/C/D: 30.0°W-75.0°E KATHREIN CAS 018 (1,8m) / Ka-band band A 2x KATHREIN CAS 120 fix on 19.2°E and 42.0°E
    C-band LNBs: Kaonsat, C-Panorama 13K, Norsat 8000RI C-DRO, BrasilSat LNBF AP30 PLL / X-band LNB: Norsat X1000HAF / Ku-band LNB: Invacom SNF-031, Inverto Single Flange / Ka-Band LNBs: Inverto Twin WHITE Ka Circular Dual Polarity LNB (flange), Inverto IDLK-SINL20-KAKU-OPP,MCL-KP04, Norsat 9000HX-O3B-BN, Orbital LNB1825F-1000D-WF55
    Feeds: Invacom ADF_10 + 2 rings, XMW Ka-band Feed FD9000K / Waveguide Polariser: AV-COMM / Tuner: TBS 6925, TBS 6903, TBS 6903X, TBS 6522
    Current scan: 21555 H 1183 and 21612 H 27580 have left... :79:
    ... 21612 H 27580 have left...
    ...and on again - no changes in content or parameter. :175:
    /edit at 18.30 CET: 21555 H is back in the evening hours. :83:
    21555 H 1183 3/5 DVB-S2 8PSK
    First time to get a lock - signal increased today :167:
    ...scrambled service: Galaxie TV (Cameroon)
    PS: 21579 H is off since few days...
    Today on 21555 H - showing Provider name: "Neo DS" - no active VPids/APids at this time.
    ...and in clear at this time (21555 H, Galaxie TV). :69:
  • Galaxie TV (from Cameroon) now with program on 21555 H
    11 fix dishes 78cm-240cm
    Ka-Band: 7E 125cm , 16E 150cm, 2 * Inverto KaKu
    C-Band: 10E: 240cm PFA - 26E: 230cm mesh - 3E: 180cm PFA - 8W: 167cm PFA LNB: 4 * Kaonsat 13K
    KU-Band: 78-150cm, multifeed
    RX: Openbox SX4/SX9, TM5402, TBS 5927, Edision Primo IP S2
    Without video data at this time - ID: E TELE
    21554 H 1100 2/3 DVB-S2 QPSK
    Guten Morgen ,
    Ich finde , dass der Empfang z.Z. nicht so gut ist, und bei manche Transponder ziemlich instabil ist .
    Wie ist es bei euch ?
    I find that the reception is currently is not so good, and quite unstable with some transponders.
    How are you all doing ?
    stephan94 - I can confirm - weaker signals at this time - using MCL-KP04 ...
    I thought something was broken. I'm using a Gilat band D LNB from an ODU with the Gilat feed (not optimised for the 1.2m Prodelin offset). Here are some comparison plots from yesterday and January 2021:
    11/1/21, left plot; 7/6/22. right plot. Whilst most are lower or changed, 21568 is ~2dB higher.
    11/1/21
    7/6/22 (21612 not shown but it is in and out of lock at around 7.8dB SNR)
  • Same situation here. Signals are weaker since several days. I also thought there is something with the LNB and maybe I should switch to my backup LNB. But you guys seem to have the same problem. On top of that there is a lot of rain now, so super bad conditions...
  • It looks, like nothing has changed in "bad situation" here...
    21534 H lockable in manual, without showing video stream...
    Not lockable at my place/setup: 21559 H, 21576 H and 21612. :37:
  • A bit better now on midday.
    Video stable now on 21534 H and 21612 H is lockable in manual scan.
    Not lockable: 21559 H and 21576 H.
