11495 H,22858,2/3,Dvb-S2X/32APSK,RollOff:0.05-Data
24.5°W Intelsat 905 (incl.)
11519 H,22858,2/3,S2X/32APSK,0.15,Multi 1-Data_
A look on these ones, using ACM:
11471 H, 11495 H, 11519 H and SR 22859
11591 V still has Multi 63,too,RollOff:0.15. I think 11608 V also is S2X(RollOff:0.15) and has Multi 63.
Checked with tbs6590 card -
Todays scan. One more temporary GS stream appeared:11591 V 25710 DVB-S2X, Packetized MIS 1
PS: Probably some more MIS....
11590 V-mode S2X/16APSK pop-up now
11466 H,15237,11/20,S2,0.05-new symbol rate ?(It's probably 11471 H posted by Qwer )
11516 H,26665,32/45,S2X/64APSK,CCM-new symbol rate and mode,
10971 H,32454,25/36,16APSK,RollOff:0.10,CCM-new S2X11516 H and 10971 H have left.
10989 H,31501,25/36,S2X/16APSK,0.05,ACM,Multi 1-Data(new S2X) -
11495 H,22858,2/3,Dvb-S2X/32APSK,RollOff:0.05-DataZitatOriginal von satesco
11519 H,22858,2/3,S2X/32APSK,0.15,Multi 1-Data_ZitatOriginal von satesco
Checked with tbs6590 cardAll these transponders have left.
what for all SR only bitrate 50 Mbit ? known this bug ?
Original von EnoSat
what for all SR only bitrate 50 Mbit ? known this bug ?Yes,it really is a bug.I don't know if CrazyCat knows about this bug.It manifests when the null packets(pid 8191) flood the stream with garbage.At least that seems to be happening. We see this in TransEdit how the number of "zero" packets increases,which leads to high bitrate and the lack of valid packets. You see this at almost s2x transponders that I posted here,most of 50Mbits,on S2X section.
I also think that,probably,this problem has to do with the signal that you have to lock these transponders with the s2x extension,many with signal at the limit,hard to capture.You can see that in the way different demodulators(SMT & Silab) read this signal and lock it.
Of course my explanation is more intuitive than professional,which is why I'm not sure it's valid
I hope crazycat to help if he's following our posts.
Regards -
10989 H,31501,25/36,S2X/16APSK,0.05,ACM,Multi 1-Data(new S2X)10986 H,41909,5/9,S2X/32APSK,0.05,Multi 1-new symbol rate,
10986 H has left.
10998 H,49876,5/9,S2X/16APSK,0.10-Data(new) -
10989 H,31501,25/36,S2X/16APSK,0.05,ACM,Multi 1-Data(new S2X)10987 H,8751,7/9,16APSK,0.05,Multi 1-Data(new symbol rate),
11019 H,12251,2/3,S2X/32APSK,0.10-Data(new s2x)added:spectr
11477 V,26252,77/90,16APSK,0.10,ACM-new Data
10989 H,31501,25/36,S2X/16APSK,0.05,ACM,Multi 1-Data(new S2X)10967 H,26664,2/3,S2X/32APSK-Data,new,
11140 H,40951,7/8,(S2X)/16APSK,0.05,Multi 1-Data,new
10989 H,10967 H,11140 H have left,
11074 H,65452,7/9,(S2X)/32APSK,CCM-Data (not new, on FS & s2 #16),
11494 H,68568,32/45,(S2X)/32APSK,CCM-Data (not new, GS #57 & s2 #16),
11594 H,34284,25/36(S2X/8PSK,0.05,CCM-Data, new symbol rate (spectrum Feci01 #66)
